We want to test various WPA3 opmodes, including wpa3-aes-ccm-128. My devices connect fine when I change our test SSID to this (using PEAP/MSCHAPv2) but they show the SSID as being WPA/WPA2 not WPA3 when I look at the network details. I was using an AP-314 and now an AP-635. Is there a way to check on the controllers what opmode ArubaOS thinks my clients are using?
I have Opmode transition disabled so I was assuming the clients would have to use WPA3 or not be able to connect? (I'm not sure which of them I would expect to support WPA3, my laptop is definitely old enough that it might be borderline, but my MacBook and Pixel are pretty recent).
Thank you,
Guy
