Confirm AP IP Address, Subnet, and Gateway
  • 1.  Confirm AP IP Address, Subnet, and Gateway
    MVP
    Posted Nov 28, 2018 09:16 AM
    Is there a way to confirm the IP address, Subnet Mask, and Gateway that an AP has? Reason for this is that we had to extend our AP VLAN from a /24 to a /23 to accomodate additional APs and I just wanted to confirm that the subnet mask is now 255.255.254.0.
    Thanks.
  • 2.  RE: Confirm AP IP Address, Subnet, and Gateway
    Posted Nov 28, 2018 10:44 AM
    You can look at the ap tech-support, OR:
    - Enable console access to the AP
    - Telnet into the AP and execute an "ifconfig" after the escape sequence.
  • 3.  RE: Confirm AP IP Address, Subnet, and Gateway
    MVP
    Posted Nov 28, 2018 11:51 AM
    I wasn't onsite physically, but we are enabling BLE Console Access for things like this moving forward. A majority of those APs were AP-125's and too high to remove to console into though.
    I will verify the ap tech-support logs and see which command in there pulls that information.
  • 4.  RE: Confirm AP IP Address, Subnet, and Gateway
    Posted Nov 28, 2018 12:34 PM
    For the 125s, you can enable Telnet access and enable console access, and you can just telnet into the APs...
  • 5.  RE: Confirm AP IP Address, Subnet, and Gateway
    MVP
    Posted Nov 28, 2018 01:53 PM
    Good point, for us we can't enable Telnet on our network as per security policy, but that's a good reminder of it's availability.
    As a side note, the command that kicks out the info is:
    show ap debug system-status ap-name <ap-name> | begin ifconfig
  • 6.  RE: Confirm AP IP Address, Subnet, and Gateway
    Posted Apr 15, 2020 07:51 AM
    In addition, the "show ap consolidated-provision info" command will show you that information:  https://www.arubanetworks.com/techdocs/ArubaOS_86_Web_Help/Content/arubaos-solutions/1cli-commands/sh-ap-consld-prv.htm?Highlight=consolidated
    (host) #show ap consolidated-provision info ap-name xxxxx-ap-135
    ap name: xxxxx-ap-135
    ipv4 address type: dynamic
    ipv4 address: 10.17.160.247
    ipv4 netmask: 255.255.255.0
    ipv4 gateway: 10.17.160.2
    ipv4 lease: 43200
    ipv4 dhcp server: 10.17.160.2
    ipv4 dns server: 10.13.6.110, 0.0.0.0
    ipv6 address: none
    master: 10.17.160.4
    master discover type: Provisioned manually
    previous lms: none
    lms addrs [0]: 10.17.160.4
    Also, the "ap consolidated-provision info" command will collect that information for all access points on that controller and put it into a "ap_provision_info.txt" file on the controller for you to review;  https://www.arubanetworks.com/techdocs/ArubaOS_86_Web_Help/Content/arubaos-solutions/1cli-commands/ap-consol-prov.htm?Highlight=consolidated
