Confirm if IAP or AP
  • 1.  Confirm if IAP or AP
    Posted Feb 25, 2015 11:10 AM
    I have a couple of AP-135s and i want to check if they are IAPs which does not need a WLAN Controller and which are APs which require a WLAN controller.
  • 2.  RE: Confirm if IAP or AP
    Posted Feb 25, 2015 11:13 AM
    The sticker on the back will say IAP-135
    Tim
  • 3.  RE: Confirm if IAP or AP
    Posted Feb 25, 2015 11:17 AM
    There are som APs, even though it was written on the boxes that they were IAPs, the sticker says AP-135 and also on the controller, all the APs are of type AP, even though i know for sure that some are IAP. Is there anywhere else i can confirm that? a command maybe?
  • 4.  RE: Confirm if IAP or AP
    Posted Feb 25, 2015 11:31 AM
    Found this in our community, may this help you..
    http://community.arubanetworks.com/t5/Unified-Wired-Wireless-Access/controller-command-to-identify-AP-or-converted-IAP/td-p/184016
    Also you can console each of them and see the booting process, for AP and IAP the booting process is different. [like AP will search for master but IAP will not]
