last person joined: 9 hours ago
Confuison regarding the Conditions in the rules ??
  • 1.  Confuison regarding the Conditions in the rules ??
    Posted Aug 19, 2013 05:35 AM
    What type of condition i have to select here ?
    there are many options related to the condition and what is the purpose of all individual ones ? What is the purpose of after selecting individuals ?
    Contians =
    Ends-with =
    Equals =
    Not Equal =
    Starts-with =
  • 2.  RE: Confuison regarding the Conditions in the rules ??
    Posted Aug 19, 2013 01:52 AM
    Thanks dear Sriram...
    Find a solution
  • 3.  RE: Confuison regarding the Conditions in the rules ??
    Posted Aug 19, 2013 06:09 AM
    The conditions are really just what they says
    Contians =
    The string from the rule type CONTAINS the value entered for example:
    BSSID = d8:c7:c8:11:22:33
    Value = c7:c8
    This would be a hit
    Ends-with =
    The string from the rule type ENDS WITH the value entered for example:
    Value = 22:33
    This would be a hit
    Equals =
    The string from the rule type EQUALS the value entered for example:
    Value = d8:c7:c8:11:22:33
    This would be a hit
    Not Equal =
    The string from the rule type DOES NOT EQUAL the value entered for example:
    Value = 11:22:33:44:55:66
    This would be a hit
    Starts-with =
    Value = d8:c7
    This would be a hit
    Hope this clarifies this for you :)
  • 4.  RE: Confuison regarding the Conditions in the rules ??
    Posted Aug 19, 2013 08:03 AM
    Dear Nesvik..
    Hatts Off to you... Wat a brilliant knowledge you given to me which i want with this way.
    Outstanding !!!! :smileyhappy:
  • 5.  RE: Confuison regarding the Conditions in the rules ??
    Posted Aug 19, 2013 08:37 AM
    According to your Answer as below
    Contians =
    BSSID = d8:c7:c8:11:22:33  ( Here, how can i write the mac address of the AP . After Selecting the BSSID there is no option to enter the mac address , just to enter the value in the next step after selecting BSSID).
    Value = c7:c8
    This would be a hit
    One thing i want to understand, after selecting the "role"  then "BSSID"  then in the " value" portion whether we have to enter the MAC-address of the AP or something else... Too much confuse... kindly help me in this regard.
  • 6.  RE: Confuison regarding the Conditions in the rules ??
    Posted Aug 19, 2013 08:57 AM
    You would enter the MAC address of the AP in the Value field.
    "Contition BSSID" would be the variable that are checked against the "value" field.
    So in plain english this would be something like:
    "Check what the currently connected BSSID (Condition BSSID) is and compare it to what I want it to Contain (Value field).
    You Cannot set the Contition Field as it is dynamicaly set to the BSSID if whatever AP the user is currently connected to :)
