Confusion between IAP, airwave and Controller Base
  • 1.  Confusion between IAP, airwave and Controller Base
    Posted Apr 11, 2017 11:58 AM
    we want to implement Aruba Wireless across our office campus. Recently a survey has been done by a partner of ARUBA and they found total 40nos of AP required (propsed series is AP210). Now i ahve following questionsmy
    1) should i go for IAP solution or a controller based solution? in near future may be another 20 APS required ( for next 2-3 years)
    2) How Controller(propsed is 7200 series) is diffrent form  aruba NMS(Airwave)?
    3) Which one will be more helpful for me NMS or Controller?
    4) I want to do user based authentiaction which one be easy to integrate windows Active Directory or Open LDAP? Should i require a Radius Server?
    Controller or IAP need to pass the user authentication inforamtion to my Fortigate UTM where user based firewall policy is want to applied.
    Note:- I have little budget constraint. Please sugget.
  • 2.  RE: Confusion between IAP, airwave and Controller Base
    Posted Apr 11, 2017 12:14 PM
    Honestly, you should consult your partner and get his opinion.  There are many reasons why you would go with either beyond the questions that you are asking right now..
