Confusion on APs UP on Controller
  • 1.  Confusion on APs UP on Controller
    Posted Aug 10, 2018 05:16 AM
    I'm currently deploying a Master Local design for a client for 32 APs,
    On the controller i have 32 UP , but later most of the go DOWN on the controller.
    I know it's a license issue because i have 34 AP license and 10 PEF license aggregated on the controller.
    I know the controller would use the least license with is 10.
    I don't understand why it would use 20 at a time, while the rest continues in a bootloop.
    Please refer to the attached out to understand and help.
    Thank you
  • 2.  RE: Confusion on APs UP on Controller
    Posted Aug 10, 2018 10:55 AM
    Thank you
    The screen shot shows the licenses available from the centralized license server perspective. What licenses are installed on the individual local controllers?
  • 3.  RE: Confusion on APs UP on Controller
    Posted Aug 10, 2018 02:14 PM
    Controller 1 Master (Aruba 7005): 24 AP Licenses
    COntroller 2 Local(Aruba 7005) : 10 AP Licenses
                                                             10 PEF Licenses
                                                             10 RF Licenses
    Controller 3 Local (Aruba 7005): No license
  • 4.  RE: Confusion on APs UP on Controller
    Posted Aug 10, 2018 02:27 PM
    Definitely strange. I suggest contacting TAC so they can capture more information about that scenario.
  • 5.  RE: Confusion on APs UP on Controller
    Posted Aug 10, 2018 03:31 PM
    Hi
    Out of ‘sync’ licenses (unequal numbers) can cause strange behavior.
    What happens if you only run with the LIC-AP, so delete the PEF and RFPROT licenses.
    Or temporarily install a trail license for PEF and RFPROT to see if that fixes it.
    Hope it helps
