Connect AP-175P console via Internet (ssh putty...)
  • 1.  Connect AP-175P console via Internet (ssh putty...)
    Posted Jul 24, 2013 05:24 AM
    Hallo,
    We want to connect AP-175P on separate DSL network  from our office via Internet.
    Problem is, that AP isn't configured to connect to public IP of controller and isnt synced with cotroller..
    If I know public IP of AP (DHCP), could I connect via Putty to public IP with SSH port 22 for
    changing IP of controller on AP???
    Thank You
  • 2.  RE: Connect AP-175P console via Internet (ssh putty...)
    Posted Jul 24, 2013 06:21 AM
    NO.
    AP-175 can be accessible only via USB CONSOLE.
    U can't SSH to the AP unit..to the IP of the unit  (part of the basic security)
    regards.
    Me
  • 3.  RE: Connect AP-175P console via Internet (ssh putty...)
    Posted Jul 24, 2013 06:52 AM
    Thank You,
    Only way is to come to AP and change ip via console?
    Could I find some advance sheets about preconfiguring ap via console  (change controller discovery IP) ?
    Thank You
    R.
  • 4.  RE: Connect AP-175P console via Internet (ssh putty...)
    Posted Jul 24, 2013 08:45 AM
    Is this already being managed by a controller?  If so, you can "move" this AP to a different controller by re-provisioning it.  You can also change the IP (if it's static) as well by re-provisioning it.
    If you prefer the console, reboot the AP while you are connected via console and interrupt the process.  At the "apboot>" prompt, issue the command "printenv".  You will see all the variables present.  To change one, use the command "setenv" along with the variable and values.
    Then issue "save" and then "reboot"
  • 5.  RE: Connect AP-175P console via Internet (ssh putty...)
    Posted Jul 24, 2013 01:38 PM
    here u got all the needed info:
    http://community.arubanetworks.com/t5/Access-Points/printenv-command-on-AP-s/td-p/2420
    *If your AP is doing IPSEC (acting as RAP) using user&password u will not be able to configure it via console*
    Default Parameters: (example only)
    apboot> printenv
    boardname=Mataro
    autostart=yes
    baudrate=9600
    bootdelay=2
    bootcmd=boot ap
    bootfile=mips.ari
    servername=aruba-master
    ethaddr=00:1a:1e:c1:f7:f8
    Aruba AP Variables
    General Variables:
    setenv ipaddr x.x.x.x
    setenv netmask x.x.x.x
    setenv gatewayip x.x.x.x
    setenv master x.x.x.x
    setenv serverip x.x.x.x
    setenv location b.f.l
    setenv group xxxxxx
    Required without DNS or option 43:
    Required without DHCP:
    Required for RAP:
    setenv name
    setenv group
    setenv a_antenna 0
    setenv g_antenna 0
    setenv ikepsk D214BF31B5C8E15031457BA12042E9F769ECB4FF789E62E4
    setenv papuser
    setenv pappasswd D99047FAB49E4C40DD560E66AE1F19C940D73CA09C32D461
    setenv auto_prov_id 9
    setenv mesh_role 0
    Please, when possible, post some 'printenv' outputs from your AP to see more details. That helps to understand AP function.
