Wired Intelligent Edge
Connect Cisco 3560 to Aruba 2530 via SFP transceivers
  • 1.  Connect Cisco 3560 to Aruba 2530 via SFP transceivers
    Posted Jun 20, 2019 06:18 PM
    Connect "Cisco 3560 series PoE-48" to "Aruba 2530 PoE-48" via SFP transceivers. We get no activity lights on the Aruba 2530 switch.
    CiscoCiscoHPe ArubaHPe Arubathumbnail_20190620_161206.jpgthumbnail_20190620_160949.jpg
  • 2.  RE: Connect Cisco 3560 to Aruba 2530 via SFP transceivers
    Posted Jun 20, 2019 09:03 PM
    mismatch gbic. The cisco is a single mode and the aruba 1 is a multi-mode. Also what ever you choose make sure to use the correct fiber cable
  • 3.  RE: Connect Cisco 3560 to Aruba 2530 via SFP transceivers
    Posted Jun 20, 2019 10:00 PM
    Ok,
    Is this what I would need then? And does "SMF" mean single mode, and "MMF" multi mode?
    Aruba 1G SFP LC LX 10km SMF Transceiver
    Link to SFP
  • 4.  RE: Connect Cisco 3560 to Aruba 2530 via SFP transceivers
    MVP GURU
    Posted Jun 21, 2019 06:25 AM
    Yes,
    but the fiber cable i think it is for MMF (from color of cable)
  • 5.  RE: Connect Cisco 3560 to Aruba 2530 via SFP transceivers
    Posted Jun 21, 2019 06:34 AM
    Well, the cisco switches with those cisco tranceivers are currently operating on the network with that orange fiber.... They have been for years. We are replacing the cisco switches with the aruba switches throughout the entire network.
  • 6.  RE: Connect Cisco 3560 to Aruba 2530 via SFP transceivers
    MVP GURU
    Posted Jun 21, 2019 07:01 AM
    The fiber optic cable shown, give its labelling, is for sure a 62.5/125 um Multi-Mode Fiber (MMF) OM1 cable.
    Given that Cisco's SFP Transceivers are LH-SM (Long Haul Single Mode, I presume) then, using a MM fiber optic cabling (as it worked), it is possible (with degradation)...I suspect the contrary (SX MM Short Range Multi Mode SFP Transceiver on SM fiber optic cabling) it's a matter of being very lucky.
    For sure there is a SFP Transceivers mismatch going on here (Aruba J4858D versus Cisco LH-SM)...probably a Cisco GLC-SX-MMD would solve the mismatch with the J4858D.
