Network Management
Connect multiple HPE Aruba switches togheter
This thread has been viewed 16 times
  • 1.  Connect multiple HPE Aruba switches togheter
    Posted Jan 16, 2022 04:20 PM
    Good evening, I had a question to ask: I need to review an infrastructure that mounts several Aruba switches. Some are connected to the root switch with one, two, or four ports configured as TRUNK; others with one, two or four ports configured in LACP; others instead with a single port tagged on the various VLANs so that it is actually a "trunk". What would be the best practices to optimize traffic sorting and correctly connect the various products (they are all HPE Aruba, some from 8, some from 24, others from 48 ports). How many lan ports should you use to connect each switch to the other?
    Thank you.
    Simone
  • 2.  RE: Connect multiple HPE Aruba switches togheter
    Posted Jan 18, 2022 05:07 AM
    That is a design question, which is extensively covered in the Aruba training curriculum Aruba Certified Design Associate/Professional/Expert.
    In general, make sure your uplinks have enough capacity to not be a bottleneck. And make sure your uplinks and the network has enough redundancy to meet your availability requirements. It really depends on your environment, and what you do with it. Most Aruba partners offer services for the design and initial setup of your network.
