Comware
  • 1.  Connect unmanaged Netgear Switch to HP J9728A 2920-48G
    Posted Apr 21, 2020 08:25 AM
    Hey!
    In our network some guys recently plugged in the cable of a network jack in an unmanaged 8-port Netgear switch.
    So Basically there is an existing connection between Port 3 of the HP J9728A 2920-48G Switch and the unmanaged 8-port Netgear switch right now.
    On our HP Switch, STP is enabled and i guess thats why i got notifications at the Switch Web Client like "port 3 is Blocked by STP"
    So right now it is not possible to reach the hardware via icmp or something else which is connected to the unmanaged switch, whereas i am located in the conventionally network behind the HP Switch.
    I guess that this behaviour should be completely right as it acts right now.
    So my question is technically:
    Why does this specific connection between the managed HP Switch and the unmanaged Netgear switch not work?
    Why i am not able to reach the respective hardware behind the unmanaged switch and what should i do to solve the problem? ( maybe just use another HP managed switch instead of the rubbish netgear switch, which is actually not possible right now) or is it just a software configuration issue?
    #unmanaged
    #J9728A
    #HP
    #managed
    #Netgear
    #STP
  • 2.  RE: Connect unmanaged Netgear Switch to HP J9728A 2920-48G
    Posted Apr 21, 2020 08:31 PM
    Hi! on your HP 2920 please execute the commands reported below:
    • show running-config interface ethernet 3
    • show spanning-tree ethernet 3
    • show spanning-tree ethernet 3 detail
    • show spanning-tree ethernet 3 config
    and paste here their outputs (sanitized = MAC Addresses obfuscated) using the "Insert/Edit code sample" </> customizing icon above for easy reading.
    It's totally possible that you have a (STP related) running configuration that protect your port 3 when another switch is connected or that your connected unmanaged switch is hiding a loop that your HP 2920 is able to diagnose (and it is configured to protect itself in such a scenario).
  • 3.  RE: Connect unmanaged Netgear Switch to HP J9728A 2920-48G
    Posted Apr 22, 2020 07:06 AM
    Switch-1-1-1# show running-config interface ethernet 3
    Running configuration:
    interface 3
       unknown-vlans block
       tagged vlan 1001-1004,1006,1008-1011,1013-1018,1029-1032,1034,1047-1051,1196,1201-1202
       untagged vlan 1
       loop-protect
       exit
    Switch-1-1-1# show spanning-tree ethernet 3
     Multiple Spanning Tree (MST) Information
      STP Enabled   : Yes
      Force Version : RSTP-operation
      IST Mapped VLANs : 1-4094
      Switch MAC Address : xxxxxx-yyyyyy
      Switch Priority    : 32768
      Max Age  : 20
      Max Hops : 20
      Forward Delay : 15
      Topology Change Count  : 5
      Time Since Last Change : 16 days
      CST Root MAC Address : xxxxxx-yyyyyy
      CST Root Priority    : 0
      CST Root Path Cost   : 2000
      CST Root Port        : A1
      IST Regional Root MAC Address : xxxxxx-yyyyyy
      IST Regional Root Priority    : 32768
      IST Regional Root Path Cost   : 0
      IST Remaining Hops            : 20
      Root Guard Ports     :
      Loop Guard Ports     :
      TCN Guard Ports      :
      BPDU Protected Ports :
      BPDU Filtered Ports  :
      PVST Protected Ports :
      PVST Filtered Ports  :
      Root Inconsistent Ports  :
      Loop Inconsistent Ports  :
                       |           Prio              | Designated    Hello
      Port  Type       | Cost      rity State        | Bridge        Time PtP Edge
      3     100/1000T  | 20000     128  Forwarding   | xxxxxx-yyyyyy 2    Yes Yes
    Switch-1-1-1# show spanning-tree ethernet 3 detail
     Status and Counters - CST Port(s) Detailed Information
      Port                      : 3
      Status                    : Up
      BPDU Protection           : No
      BPDU Filtering            : No
      PVST Protection           : No
      PVST Filtering            : No
      Errant BPDU Count         : 0
      Root Guard                : No
      Loop Guard                : No
      TCN Guard                 : No
      MST Region Boundary       : Yes
      External Path Cost        : 20000
      External Root Path Cost   : 2000
      Administrative Hello Time : Global
      Operational Hello Time    : 2
      AdminEdgePort             : No
      Auto Edge Port            : Yes
      OperEdgePort              : Yes
      AdminPointToPointMAC      : True
      OperPointToPointMAC       : Yes
      Aged BPDUs Count          : 0
      Loop-back BPDUs Count     : 0
      TC ACK Flag Transmitted   : 0
      TC ACK Flag Received      : 0
      MST        MST        CFG        CFG        TCN        TCN
      BPDUs Tx   BPDUs Rx   BPDUs Tx   BPDUs Rx   BPDUs Tx   BPDUs Rx
      0          0          0          0          0          0
    Switch-1-1-1# show spanning-tree ethernet 3 config
     Multiple Spanning Tree (MST) Configuration Information
      STP Enabled [No] : Yes
      Force Version [MSTP-operation] : RSTP-operation
      Default Path Costs [802.1t] : 802.1t
      Port State Events Logging : Disabled
      MST Configuration Name : xxxxxx-yyyyyy
      MST Configuration Revision : 0        Switch Priority : 32768
      Forward Delay [15] : 15               Hello Time [2] : 2
      Max Age [20] : 20                     Max Hops [20] : 20
                      | Path      Prio Admin Auto Admin Hello  Root TCN Loop BPDU
      Port Type       | Cost      rity Edge  Edge PtP   Time   Grd  Grd Grd  Flt
      3    100/1000T  | Auto      128  No    Yes  True  Global No   No  No   No
  • 4.  RE: Connect unmanaged Netgear Switch to HP J9728A 2920-48G
    Posted Apr 22, 2020 09:36 AM
    Hi, well the port 3 is in Forwarding state...so STP is not blocking that port (actually). I strongly suspect (the reason, from the Unmanaged Netgear switch, was explained here) that the only packet's tagging understood and admitted by the Unmanaged Netgear Switch is indeed the "untagged" one thus the VLAN id 1 you configured the port 3 to be untagged member of; any other packet leaving the port 3 tagged with any of the VLAN ids you have the port 3 configured to be member of (VLAN id 1001-1004, 1006, 1008-1011, 1013-1018, 1029-1032, 1034, 1047-1051, 1196 and 1201-1202 [*]) is going to be dropped on the incoming port of the Unmanaged Switch.
    Since you already have RSTP enabled, I suggest you to setup root-guard, bpdu-protection and loop protection on port 3...see here to understand why.
    [*] A nice way to easily understand, from the port standpoint, how is the VLAN membership on a particular port (or range) is to use the show vlan port <port-id> detail command.
  • 5.  RE: Connect unmanaged Netgear Switch to HP J9728A 2920-48G
    Posted Apr 22, 2020 12:35 PM
    So in addition, all the components behind the unmanaged switch are in VLAN 1 and apart from that, the managed HP switch is also in VLAN 1
    So concerning your statement "Since you already have RSTP enabled, I suggest you to setup root-guard, bpdu-protection and loop protection on port 3...see here to understand why."
    Who do i do that?
  • 6.  RE: Connect unmanaged Netgear Switch to HP J9728A 2920-48G
    Posted Apr 22, 2020 07:40 PM
    Sorry, do you want to really ask: Why or How I do that? ...I really can't understand the "Who do i do that?" question.
  • 7.  RE: Connect unmanaged Netgear Switch to HP J9728A 2920-48G
    Posted Apr 23, 2020 10:42 AM
    Sorry, i must have been mentally absent at the time.
    Yeah, i want to know, why do i have to do that and especially how, so which commands do i have to use?
  • 8.  RE: Connect unmanaged Netgear Switch to HP J9728A 2920-48G
    Posted Apr 30, 2020 10:46 AM
    @parnassus Do you have more information for me right now?
  • 9.  RE: Connect unmanaged Netgear Switch to HP J9728A 2920-48G
    Posted Apr 30, 2020 05:18 PM
    Hello, isn't the content available at the second link I provided you already self-explaining enough?
    IMHO that blog entry (in a more discorsive way with respect to what official reference guides are generally able to provide) there is the "Why" (protect your network) against the "Who" (can cause you issues) and the "How" (do that in terms of configuration) specifying the "Where" (you should enforce your protective mechanisms).
  • 10.  RE: Connect unmanaged Netgear Switch to HP J9728A 2920-48G
    Posted May 04, 2020 05:15 AM
    @parnassus in the meantime I have found out something new.
    So the device which is plugged in to the unmanaged switch, is located in the default, untagged VLAN.
    So from any device in this VLAN, i am able to reach this device via icmp but if i try to reach the respective device on the unmanaged switch from another vlan, i get back a timeout. So no connection is possible.
    So IMHO i guess, i am not able to reach that device from another VLAN because the unmanaged switch didn't tagg the ethernet packet with the expected VLAN ID or pvid ?
    Do you have any idea, how i could be able to reach this device from another specific vlan ? Maybe with masquerading or NAT or something else?
  • 11.  RE: Connect unmanaged Netgear Switch to HP J9728A 2920-48G
    Posted May 12, 2020 08:17 AM
    @parnassus do you have any update to my latest comment?
