connect via sah key to IAP
  • 1.  connect via sah key to IAP
    Posted Nov 13, 2017 05:51 AM
    Helo,
    I Know ther is auch solution vor Controller to connect to without password authwntication with ssh, is ther a similar solution for the Instant Access Points? I want to send a command out of a Script to the IAP 205
    #AirheadsMobile
  • 2.  RE: connect via sah key to IAP
    Posted Nov 13, 2017 06:05 AM
  • 3.  RE: connect via sah key to IAP
    Posted Nov 13, 2017 06:17 AM
    Thenks for the Support, if tryed it like that but without success
    #AirheadsMobile
  • 4.  RE: connect via sah key to IAP
    Posted Nov 13, 2017 06:19 AM
    Which post?  Please look at the post in the solution.
  • 5.  RE: connect via sah key to IAP
    Posted Nov 13, 2017 06:25 AM
    I apologize.  You said IAP.  I did not pay attention to that.
  • 6.  RE: connect via sah key to IAP
    Posted Nov 13, 2017 06:18 AM
    If i Do like that the Access Point wan't a password
    #AirheadsMobile
  • 7.  RE: connect via sah key to IAP
    #AirheadsMobile
  • 8.  RE: connect via sah key to IAP
    Posted Nov 13, 2017 07:28 AM
    I've tryed both solutions bot no one work for me... Can it be the solution only work on Aruba Controller Not on IAP?
    #AirheadsMobile
  • 9.  RE: connect via sah key to IAP
    #AirheadsMobile
  • 10.  RE: connect via sah key to IAP
    Posted Nov 13, 2017 07:31 AM
    I don't see anywhere that public key authentication works on IAPs.
  • 11.  RE: connect via sah key to IAP
    Posted Nov 13, 2017 07:36 AM
    Is ther a solution for IAP?
    #AirheadsMobile
  • 12.  RE: connect via sah key to IAP
    Posted Nov 13, 2017 07:37 AM
    Okay thank you
    #AirheadsMobile
  • 13.  RE: connect via sah key to IAP
    Okay thank you
    #AirheadsMobile
  • 14.  RE: connect via sah key to IAP
    Posted Nov 13, 2017 07:52 AM
    Is ther an other way to send an "disconnect user" command to the IAP with out password authentication?
    #AirheadsMobile
  • 15.  RE: connect via sah key to IAP
    Posted Nov 13, 2017 07:58 AM
    The only other ways require password authentication:
    1.  XML-API http://community.arubanetworks.com/t5/Controller-less-WLANs/How-to-add-delete-clients-using-XML-API-for-IAP/ta-p/292469
    2.  An expect script...
  • 16.  RE: connect via sah key to IAP
    Posted Nov 13, 2017 08:23 AM
    Okay thank you very much
    #AirheadsMobile
