I have network running on fw 10.13.1030 with fully functional FreeRadius setup and mac authentication enabled in switch ports with following configuration:
interface 1/1/4
no shutdown
flow-control rxtx
vlan access 1
aaa authentication port-access client-limit 8
aaa authentication port-access mac-auth
enable
At this moment in this port there is 100mbps video controller with static ip connected at the moment and last log entry for the port says:
2024-08-25T14:01:29.896816+03:00 ..... hpe-mstpd[2642]: Event|2012|LOG_INFO|AMM|1/1|CIST - Topology Change generated on port 1/1/4 going in to forwarding...
But mac-address table for the port is empty?!? How is that possible? Does port-access drop mac off in some situations? Another thing is that I cannot see mac-address in log entries either.
I have about 1500 devices in this network and from that count about 99% works just fine with port-access configuration above but there seems to be few device models wich refuses to pass mac-address to switch if device has static ip address (I'm not absolutely sure if dhcp/static ip addressing has nothing to do with this problem) Rest of the devices does not have any problems what so ever.
Is there something missing from my configuration?
Jori Luoto
AV-IT Specialist
