last person joined: 11 hours ago
Connected devices.
  • 1.  Connected devices.
    Posted Jun 12, 2024 09:11 AM
    We are operating several HP Instant switches and can only see directly connected devices.
    Our WiFi network uses a different brand, and devices connected via WiFi do not appear in the connected clients list.
     However, when we check the port where the WiFi is connected, we can see these devices. Is there a way to display these devices in the connected clients list?
    Thanks!
  • 2.  RE: Connected devices.
    Posted Jun 12, 2024 09:14 AM
    Not sure what switches you have. As you mention Instant, it may be InstantON switches, which have a separate forum here that you can use to ask your questions.
    If these are not InstantON switch, please share the type of switches and the management platform that you use.
  • 3.  RE: Connected devices.
    Posted Jun 12, 2024 10:25 AM
    Hi Herman,
    It are indeed the instant on version
    1830/1930/1960
    I have created a new post in the other community.
    Thanks!
    Met vriendelijke groet / Kind regards,
    Stephan Phillips
    Bestuurder
    sp@proofit.be
    +32 3 546 01 39
    Straatsburgdok-Noordkaai 3
    2030 Antwerpen
    België
    Proof IT
