Connected wifi clients dropping
  • 1.  Connected wifi clients dropping
    Posted Jan 14, 2014 09:27 PM
    We are having some issues here. our Wifi clients kept dropping from the Aruba APs. The APs are connected using power adaptors and was not rebooted.
    Can advise what is likely the issues?
    Roy Chan
  • 2.  RE: Connected wifi clients dropping
    Posted Jan 14, 2014 09:41 PM
    We are missing information:
    How log has this been happening?
    How old is the network?
    How many access points and what type?
    What type of clients are dropping?
    Are you using encryption?
  • 3.  RE: Connected wifi clients dropping
    Posted Jan 14, 2014 10:15 PM
    its intermittent but in recent 2 weeks it is like daily.
    Theres' no changes in the network for at least 5 years
    There are 9 AP provisioned. the model of the AP is AP61.
    Users are connected via WPA tkip. usually the users disconnect, the ssid is still broadcasting but users will have to manually reconnect 2-3min later.
  • 4.  RE: Connected wifi clients dropping
    Posted Jan 14, 2014 10:19 PM
    What version of ArubaOS and what type of controller?
  • 5.  RE: Connected wifi clients dropping
    Posted Jan 14, 2014 10:20 PM
    Controller is Aruba 800
    AOS is 3.3.3.4
  • 6.  RE: Connected wifi clients dropping
    Posted Jan 14, 2014 10:24 PM
    How many clients simultaneously?
    Do the wireless clients share a VLAN with wired clients?
  • 7.  RE: Connected wifi clients dropping
    Posted Jan 14, 2014 10:26 PM
    Random
    No, the wireless client get dhcp from contoller.
  • 8.  RE: Connected wifi clients dropping
    Posted Jan 14, 2014 10:27 PM
    Are there other businesses around you with Wifi?
    Is there a microwave in your space?
  • 9.  RE: Connected wifi clients dropping
    Posted Jan 14, 2014 10:32 PM
    we are in a building in the business district. this floor is for my office use only. But i do see some rogue aps less than 10.
    No
  • 10.  RE: Connected wifi clients dropping
    Posted Jan 14, 2014 10:36 PM
    What is the maximum number of users that are seen on Wifi?
    Your software is very old so it is possible that there are fixes for your issue in upated versions of software.  Your controller and access points are also End-Of-Life.  The best long-term solution is to upgrade your software and hardware.  Upgrade your software, because there are hundreds of fixes for device disconnects that has been released since your software came out.  You should get more dual-band access points and a newer controller so you can take advantage of the 5ghz spectrum....and the additional throughput of 802.11n and 802.11ac...
  • 11.  RE: Connected wifi clients dropping
    Posted Jan 14, 2014 11:44 PM
    Around 60 -80 users.
  • 12.  RE: Connected wifi clients dropping
    Posted Jan 15, 2014 08:33 AM
    Hello!
    I agree with cjoseph that both hardware and software are very old and that's You have to plan to change very soon and move to 5GHz band which is not so crowded yet.
    But until You do that...
    1. Which type of clients is connecting on your wireless network (Windows, Linux, MAC...)?
    2. Which model of wireless NIC you have in your computers?
    3. Did You have ARM activated on controller ?
    If there is no changes done in configuration for a long period the first thing I think on is a interferers:
    * Bluetooth (new headsets in office?)
    * cordless phones (new phones in office?)
    * video and audio stream devices
    * RFID Readers
    * smartphones acting as AP,
    * other WiFi-networks in building sharing the same channel.
    You need hire someone who has a spectrum analyser to see if there is any interferers around You.
    Maybe there is someone who trying to perform some type of wireless attack on your network - check firewall logs.
