Connecting 3 IAPs to S1500-12P to cable modem
  • 1.  Connecting 3 IAPs to S1500-12P to cable modem
    Posted Aug 29, 2015 04:41 PM
    Greetings all,
    I have what might be a simple/stupid issue you might find right away, my issue is that my devices are getting IP addresses from the IAP DHCP depending on the VLAN, but I'm not getting any packets beyond the IAPs/virtual controller.
    I have three IAPs: one IAP-215 as the VC, and two other IAP-205.
    I have three WLANs, each has it's own VLAN networks.
    I'm able to join each WLAN and the appropriate IP addreses are given to me, but I can't get beyond the IAP network. Am I missing something? I was under the impression the VC could also handle routing.
    Thanks very much!
  • 2.  RE: Connecting 3 IAPs to S1500-12P to cable modem
    Posted Aug 30, 2015 12:01 AM
    Follow up: I changed the IAPs to DHCP themselves and plugged into my existing network. All IAPs were given IPs from an external DHCP but could not ping the gateway that gave the IAPs their IP address. Hmmm...
  • 3.  RE: Connecting 3 IAPs to S1500-12P to cable modem
    Posted Aug 31, 2015 06:10 AM
    HI,
    When you create a WLAN with VC assigned IP, Clients will get IP from VC and VC will NAT the Client traffic by using VC IP address.
    Please provide more details on this,
    1. Which IP assignment option you have selected ?
    2. Which DHCP option you have selected in IAP ?
    If possible share the snap shot of your config so that I can understand and help you on fixing the issue.
  • 4.  RE: Connecting 3 IAPs to S1500-12P to cable modem
    Posted Aug 31, 2015 06:44 PM
  • 5.  RE: Connecting 3 IAPs to S1500-12P to cable modem
    Posted Aug 31, 2015 06:45 PM
  • 6.  RE: Connecting 3 IAPs to S1500-12P to cable modem
    Posted Aug 31, 2015 06:46 PM
    Greetings! This setup is going into a coffee shop, and the master IAP VC will be giving out IPs to each WLAN. I know the switch uplink is working since the IAPs are grabbing IPs from a larger test network for themselves.
  • 7.  RE: Connecting 3 IAPs to S1500-12P to cable modem
    Posted Sep 05, 2015 12:14 AM
    Still not sure what's going on - I'm guessing it may be some reason why routing isn't working on the devices.
  • 8.  RE: Connecting 3 IAPs to S1500-12P to cable modem
    Posted Sep 08, 2015 07:17 PM
    From the documentation:
    Configuring DHCP Scopes:
    Local—In this mode, the Virtual Controller acts as both the DHCP Server and the default gateway. The
    configured subnet and the corresponding DHCP scope are independent of subnets configured in other IAP
    clusters. The Virtual Controller assigns an IP address from a local subnet and forwards traffic to both
    corporate and non-corporate destinations. The network address is translated appropriately and the
    packet is forwarded through the IPSec tunnel or through the uplink. This DHCP assignment mode is used in the NAT forwarding mode.
    * Local, L2—In this mode, the Virtual Controller acts as a DHCP server and the gateway located outside the IAP.
    * Local, L3— This DHCP assignment mode is used with the L3 forwarding mode. In this mode, the Virtual
    Controller acts as a DHCP server and the gateway, and assigns an IP address from the local subnet. The IAP routes the packets sent by clients on its uplink. The Local, L3 subnets can access corporate network through the IPsec tunnel. The network address for all client traffic, which is generated in the Local, L3 subnets and destined to the corporate network, is translated at the source with the tunnel inner IP. However, if corporate access to Local, L3 is not required, you can configure ACL rules to deny access.
  • 9.  RE: Connecting 3 IAPs to S1500-12P to cable modem
    Posted Sep 09, 2015 12:25 AM
    After all that, I just changed the scopt from "Local,L3" to "Local" and it worked.
