Connecting an AP-104 to an ANT-18
  • 1.  Connecting an AP-104 to an ANT-18
    Posted May 16, 2013 04:05 PM
    I recently purchased 2x AP-104s and 2x ANT-18s:
    I found this documentation on the site for connecting an ANT-18 to an AP-92 REF: https://arubanetworkskb.secure.force.com/pkb/articles/HowTo/How-to-connect-AP-92-to-ANT-17-or-ANT-18 – however, the AP-104s have 4x ports – which ports do I use to connect the ANT-18?
    I understand that the center connection on the ANT-18 is not used - which ports on the AP-104 should the left and right ANT-18 connections be plugged into, respectively?
    Ports: R1/A1 and R0/A1 or
    Ports: R0/A0 and R1/A0 or
    Ports: R1/A0 and R1/A1 or
    Ports: R0/A0 and R0\A1
    My understanding is that the:
    R0/A0 and R0/A1 are the A Radios
    R1/A0 and R1/A1 are the B/G Radios
    Is this correct?
    Any assistance would be very helpful
  • 2.  RE: Connecting an AP-104 to an ANT-18
    Posted May 16, 2013 04:27 PM
    On the AP-104:
    R0/A0 is 5GHz
    R0/A1 is 5GHz
    R1/A0 is 2.4GHz
    R1/A1 is 2.4GHz
    When using the ANT-18, you only connect two of the connections.    I am not sure if it matters, but I would use R0/A0 and R1/A0.
  • 3.  RE: Connecting an AP-104 to an ANT-18
    Posted May 16, 2013 05:09 PM
    Thank you for the feedback. I'll get these installed using your recommendation.
  • 4.  RE: Connecting an AP-104 to an ANT-18
    Posted Sep 05, 2013 07:22 AM
    But do you need 2 ANT-18's to enable both 2.5 and 5ghz at the same time?
    Regards!
    Jeroen
