Connecting Ap135 to Master Controller 3600
  • 1.  Connecting Ap135 to Master Controller 3600
    Posted Nov 10, 2014 04:02 PM
    Recently, I received a replacement AP-135 for my network. I am attempting to provision it to my network and receive the same security parameters as my existing APs.
    I've staticly assigned the MAC to an IP. I've also programmed the console AP to the following:
    setenv ipaddr x.x.x.x
    setenv netmask x.x.x.x
    setenv gatewayip x.x.x.x
    saveenv
    boot
    Would anyone have experienced this issue before or could point me in a direction?
    #3600
  • 2.  RE: Connecting Ap135 to Master Controller 3600
    Posted Nov 10, 2014 04:36 PM
    What is the issue you are experiencing ?
    Is the AP not able to connect to the controller?
  • 3.  RE: Connecting Ap135 to Master Controller 3600
    Posted Nov 10, 2014 04:42 PM
    I can't get it to boot to an IP.
    It continually cycles:
    " eth0: down
     eth1:down
    ADP multicast: 1
    ADP broadcast: 1"
    repeatedly.
  • 4.  RE: Connecting Ap135 to Master Controller 3600
    Posted Nov 10, 2014 04:47 PM
    It looks like is not able to get an IP , can you get an IP if you plug your laptop to that same port / vlan
  • 5.  RE: Connecting Ap135 to Master Controller 3600
    Posted Nov 10, 2014 04:53 PM
    Yep, I've tested this same port on APs and have received function.
    This is not the same APs we have in our environment. Could this be in part to the problem?
  • 6.  RE: Connecting Ap135 to Master Controller 3600
    Posted Nov 10, 2014 05:02 PM
    What version of AOS are you running ?
  • 7.  RE: Connecting Ap135 to Master Controller 3600
    Posted Nov 10, 2014 05:38 PM
    6.1.2.6
  • 8.  RE: Connecting Ap135 to Master Controller 3600
    Posted Nov 23, 2014 09:20 AM
    how do you do master discovery, it the VLAN attached to the controller or do you do DNS based master discovery?
    i assume you don't have DHCP on that network?
