Connecting to Aruba-wifi Google Pixel
This thread has been viewed 30 times
  • 1.  Connecting to Aruba-wifi Google Pixel
    Posted Sep 07, 2021 02:02 AM
    Wifi in our environment is working for all, but one user with Google pixel couldn't connect even if the user membership and call are ok.
    Error Code: 215
    Error Category: Authentication failure (domain username and password are entered correctly)
    Error messagge:TLS session error
    Radius: EAP-PEAP: fatal alert by client- unknow ca
    ERROR in establishing TLS session...
    Any suggestion , advice ?
    Many thanks,
    Binod
    Binod Ranabhat
  • 2.  RE: Connecting to Aruba-wifi Google Pixel
    Posted Sep 07, 2021 02:35 AM
    from where do you get those logs?
    This indicates that some trusts are not established. I would assume, that your client (pixel phone) does not trust your radius server certificate.
    Florian Baaske
    Also visit the AirHeads Youtube Channel:
    https://www.youtube.com/channel/UCFJCnuXFGfEbwEzfcgU_ERQ
    Feel free to visit my personal Blog
    https://www.flomain.de
  • 3.  RE: Connecting to Aruba-wifi Google Pixel
    Posted Sep 07, 2021 09:32 AM
    Thank you for your reply.
    Is there any way to resolve it  such that Google Pixel device will trust our certificate and will allow the connection ?
    Many thinks.
    Kind regards,
    Binod
    Binod Ranabhat
  • 4.  RE: Connecting to Aruba-wifi Google Pixel
    Posted Sep 07, 2021 09:49 AM
    You will need to deploy the Root CA that issued your ClearPass EAP/RADIUS certificate to the Android device, and select that as Trusted certificate in the configuration.
    Best to use Device Management (MDM/EMM) for that. Also best to avoid PEAP/MSCHAPv2 as it introduces risks if you don't fully control and harden your clients.
  • 5.  RE: Connecting to Aruba-wifi Google Pixel
    Posted Sep 09, 2021 04:12 AM
    Thank you Herman.
    Is that the Root CA issued by Domain CA server or Radius server  certificate, that we need to install on the device ?
    Please let me know..I am bit new in this area.
    Many Thanks.
    Kind regards,
    Binod
    Binod Ranabhat
  • 6.  RE: Connecting to Aruba-wifi Google Pixel
    Posted Sep 09, 2021 05:53 AM
    If you check in ClearPass the certificate installed for EAP/RADIUS, follow the path to the Root CA that issued that certificate, that is the one you need to install on your client devices for the trust.
    In the case your RADIUS certificate was issued by AD Certificate Services, that is RootCA of your AD CS; and you had to install that in the ClearPass Trust list as well to get the EAP/RADIUS certificate installed, so you can export it from there, if needed.
