Connecting to Wireless Projector
  • 1.  Connecting to Wireless Projector
    Posted Sep 23, 2016 02:08 PM
    We're in the midst of setting up an Epson wireless projector. It's connected to one of our SSID's - the client machine is connected to the same SSID and it is able to find the projector using the easymp app.
    The problem is: it does not display the client's machine's screen - Is there something in the VAP profile that needs to be disabled or enabled? Or perhaps something in the stateful firewall?
    Thanks.
  • 2.  RE: Connecting to Wireless Projector
    Posted Sep 23, 2016 02:21 PM
    Do you have airgroup enabled ?
    Get Outlook for iOS
  • 3.  RE: Connecting to Wireless Projector
    Posted Sep 23, 2016 03:17 PM
    yes - I don't know which service it would use though...
    I see under advanced services->air group that all of the default services are disabled.
  • 4.  RE: Connecting to Wireless Projector
    Posted Sep 27, 2016 05:38 PM
    I am not sure if Airgroup will recognize epson projector.
    Please try the following steps:
    1. Ensure that client/projector are in a role which allows complete access to network.
    2. Turn off broadcast filter knob in the VAP profile & check the behavior.
  • 5.  RE: Connecting to Wireless Projector
    Posted Nov 01, 2016 09:31 PM
    About: "Turn off broadcast filter knob in the VAP profile & check the behavior."  Where is it? Is the "VAP > VAP_prof > DMO check box?
    I detect port 3260 over TCP and UDP (i just use nestat to check).
    Could we do a new "Airgroup" service? (If yes: how to do it too please)
    Best regards.
  • 6.  RE: Connecting to Wireless Projector
    Posted Jan 31, 2017 11:41 PM
    Virtual AP profile-->Drop Broadcast and Unknown Multicast
    The above option should be disabled.
