Hi community.
I am making a network design and I will have to connect two Aruba 8320 switches using two links with X142 40G QSFP+ MPO SR4 transceivers (JH231A) to implement VSX.
I have some doubts:
1. For these MPO transceivers, what is the position of the key slot?, is up or is down?
2. Depending on the position of the key slot in the transceiver, what MPO Trunk Cable type should I use: A or B?, what is the position of the key at both ends of this MPO trunk cable?
Thanks in advacefor your support.
Regards
#8320
