Please check the Aruba Transceiver guide if you have the proper transceiver. On page 88 there is an overview of the supported 4x4 part numbers, and as well a documented limitation that 100Mbps is not supported. As well the CX version needs to be 10.08 or higher, but I think that is the initial version for the 6000 switch.
Original Message:
Sent: May 16, 2023 11:48 AM
Subject: Connection between an Aruba 6000 and a Dlink DGS-3630-28SC via SFP
Hi
I try to connect an Aruba 6000 and a Dlink DGS-3630-28SC via SFP and it doesn't work if I connect them between the Aruba SFP port with a J4858D transceiver to one of the 20 SFP port with a DEM-311GT transceiver, but if I put the transceiver on the D-Link in one of the 4 Combo port the link is up and working
Does any one has already seen that?
Frédéric Besse
