That looks like Airwave or another management system logging in to get your configuration.
Original Message:
Sent: May 14, 2023 03:32 AM
Subject: Connection Denial due to "Incorrect Passphrase"
I have a lot of detection of rogue APs. I also have what appears to be logins and commands being executed.
May 9 12:03:53 2023 cli[17877]: USER: admin has logged in from X.X.X.X.
May 9 12:03:53 2023 cli[17877]: USER: admin connected from X.X.X.X has logged out.
May 9 12:03:53 2023 cli[17877]: USER:admin@X.X.X.X NODE:"/mm/mynode" COMMAND:<no paging > -- command executed successfully.
May 9 12:03:53 2023 cli[17877]: USER:admin@X.X.X.X NODE:"/mm/mynode" COMMAND:<encrypt disable > -- command executed successfully.
Im seeing this string of output all through my logs. Any suggestions?
Original Message:
Sent: May 12, 2023 12:00 PM
Is it still going on? Maybe check to see if there is a rogue detected on nearby APs?
Dustin Burns
ACCX 1271| ACMX 509| ACSP | ACDA | MVP Guru 2022-2023
Original Message:
Sent: May 12, 2023 03:09 AM
Hello Airheads,
Had a weird issue the other day. My users were kicked off of the SSID and then prompted to re-connect. When they attempted to re-connect they were denied due to "Incorrect Passphrase" but the passphrase hadn't been changed. What might have caused this?
