I am currently testing 1 AP-105. This is connected to a port on my firewall, where I have set everything open, but sometimes I have some problems. The problem seems to be that most sites users go to will be hit or miss on of they will load, or when they will load. For example when trying to go to www.cnn.com might not work, but checking after 5 minutes it will. Then it might only load the very basic html copy of the site, with everything striped out, until you refresh and eventually get the full version of the site. Local content, such as file shares and even Spiceworks provide no issues for the wireless connections. It only seems to be content and data coming from the internet. Also, e-mail connections and logmein connections will be connected with no issues even if you're unable to get to another site that is, in fact, up.
Here is a copy of my log file:
12/16/2013 19:57:43 PM Target: AP_Receptie Command: show log debug
Dec 16 19:55:28 awc[1009]: Message over SSL from 10.0.14.10, SSL_read() returned 0, Message is "", AWC response: HTTP/1.1 302 ^M Server: ^M Date: Mon, 16 Dec 2013 18:54:28 GMT^M Cache-Control: no-cache,no-store,must-revalidate,post-check=0,pre-check=0^M Location: https://10.0.14.10:4343/swarm^M Content-Type: text/html; charset=utf-8^M Content-Type: text/html; charset=utf-8^M Connection: close^M ^M <HTML> <HEAD><TITLE>302 </TITLE></HEAD> <BODY BGCOLOR="#cc9999" TEXT="#000000" LINK="#2020ff" VLINK="#4040cc"
> <H4>302 </H4> <ADDRESS><A HREF="http://www.arubanetworks.com"></A></ADDRESS> </BODY> </HTML>
Dec 16 19:55:28 syslogd: Syslogd error: Unable to parse find msg id 0
Dec 16 19:55:28 awc[1009]: Sent header(len=274) 'POST /swarm HTTP/1.1^M Host: 10.0.14.10^M Content-Length: 0^M X-Type: login^M X-Guid: 302035870170deb51978ae8edc435ea4ea2a2192bdcc978528^M X-Name: Instant-CD:FA:07^M X-Organization: ^M X-Shared-Secret: WIfi6622^M X-OEM-Tag: Aruba^M X-Ap-Info: BT0750379, 24:de:c6:cd:fa:07, AP-105^M ^M '
Dec 16 19:55:28 awc[1009]: Message over SSL from 10.0.14.10, SSL_read() returned 0, Message is "", AWC response: (null)
Dec 16 19:55:41 mini_httpd[12916]: tp_acl_cp_user_get: 1489: Could not retrieve valid data from datapath for session '10.0.14.49'-'10.0.14.48'
Dec 16 19:55:41 awc[1009]: Message over SSL from 10.0.14.10, SSL_read() returned 0, Message is "", AWC response:
Dec 16 19:56:00 mdns[1041]: trace_rotate_file: rotating /var/log/trace/mdns.log
Dec 16 19:56:00 mdns[1041]: trace_on: tracing to "/var/log/trace/mdns.log" started
Dec 16 19:56:00 awc[1009]: Message over SSL from 10.0.14.10, SSL_read() returned 0, Message is "", AWC response:
Dec 16 19:56:11 mini_httpd[12933]: tp_acl_cp_user_get: 1489: Could not retrieve valid data from datapath for session '10.0.14.49'-'10.0.14.48'
Dec 16 19:56:11 awc[1009]: Message over SSL from 10.0.14.10, SSL_read() returned 0, Message is "", AWC response:
Dec 16 19:56:41 mini_httpd[12953]: tp_acl_cp_user_get: 1489: Could not retrieve valid data from datapath for session '10.0.14.49'-'10.0.14.48'
Dec 16 19:56:46 mini_httpd[12952]: handle_request: 1794: got nothing, child exit after 0 requests
Dec 16 19:57:11 mini_httpd[12970]: tp_acl_cp_user_get: 1489: Could not retrieve valid data from datapath for session '10.0.14.49'-'10.0.14.48'
Dec 16 19:57:14 mini_httpd[12971]: tp_acl_cp_user_get: 1489: Could not retrieve valid data from datapath for session '10.0.14.49'-'10.0.14.48'
Dec 16 19:57:14 syslog: User admin IP 10.0.14.49 login by web UI successfully
Dec 16 19:57:15 mini_httpd[12982]: tp_acl_cp_user_get: 1489: Could not retrieve valid data from datapath for session '10.0.14.49'-'10.0.14.48'
Dec 16 19:57:15 mini_httpd[12983]: tp_acl_cp_user_get: 1489: Could not retrieve valid data from datapath for session '10.0.14.49'-'10.0.14.48'
Dec 16 19:57:15 mini_httpd[12987]: tp_acl_cp_user_get: 1489: Could not retrieve valid data from datapath for session '10.0.14.49'-'10.0.14.48'
Dec 16 19:57:15 mini_httpd[12988]: tp_acl_cp_user_get: 1489: Could not retrieve valid data from datapath for session '10.0.14.49'-'10.0.14.48'
Dec 16 19:57:15 mini_httpd[12986]: tp_acl_cp_user_get: 1489: Could not retrieve valid data from datapath for session '10.0.14.49'-'10.0.14.48'
Dec 16 19:57:16 mini_httpd[12991]: tp_acl_cp_user_get: 1489: Could not retrieve valid data from datapath for session '10.0.14.49'-'10.0.14.48'
Dec 16 19:57:16 mini_httpd[12994]: tp_acl_cp_user_get: 1489: Could not retrieve valid data from datapath for session '10.0.14.49'-'10.0.14.48'
Dec 16 19:57:16 mini_httpd[12993]: tp_acl_cp_user_get: 1489: Could not retrieve valid data from datapath for session '10.0.14.49'-'10.0.14.48'
Dec 16 19:57:16 mini_httpd[12992]: tp_acl_cp_user_get: 1489: Could not retrieve valid data from datapath for session '10.0.14.49'-'10.0.14.48'
Dec 16 19:57:16 mini_httpd[12995]: tp_acl_cp_user_get: 1489: Could not retrieve valid data from datapath for session '10.0.14.49'-'10.0.14.48'
Dec 16 19:57:17 mini_httpd[12991]: tp_acl_cp_user_get: 1489: Could not retrieve valid data from datapath for session '10.0.14.49'-'10.0.14.48'
Dec 16 19:57:17 mini_httpd[12994]: tp_acl_cp_user_get: 1489: Could not retrieve valid data from datapath for session '10.0.14.49'-'10.0.14.48'
Dec 16 19:57:18 mini_httpd[12986]: tp_acl_cp_user_get: 1489: Could not retrieve valid data from datapath for session '10.0.14.49'-'10.0.14.48'
Dec 16 19:57:18 mini_httpd[13002]: tp_acl_cp_user_get: 1489: Could not retrieve valid data from datapath for session '10.0.14.49'-'10.0.14.48'
Dec 16 19:57:19 awc[1009]: Writing on SSL connection failed even after 25 tries, Error code: 5
Dec 16 19:57:19 awc[1009]: disconnected from airwave 10.0.14.10
Dec 16 19:57:19 cli[1026]: <341004> <WARN> |AP AP_Receptie@10.0.14.10 cli| awc_logout
Dec 16 19:57:19 awc[1009]: [truncated] awc_login: 1621: writing device_cert_pem='-----BEGIN CERTIFICATE----- MIIG4zCCBcugAwIBAgIKfBqYrQAAAE6QszANBgkqhkiG9w0BAQUFADBdMRMwEQYK CZImiZPyLGQBGRYDY29tMR0wGwYKCZImiZPyLGQBGRYNYXJ1YmFuZXR3b3JrczES MBAGCgmSJomT8ixkARkWAmNhMRMwEQYDVQQDEwpERVZJQ0UtQ0ExMB4XDTEzMDgy MjAyMTc0NloXDTMyMDkxNDAzMjExNFowJzElMCMGA1UEAxMcQlQwNzUwMzc5Ojoy NDpkZTpjNjpjZDpmYTowNzCCASEwDQYJKoZIhvcNAQEBBQADggEOADCCAQkCggEA tuy2hfo7ZXiF0u7IuQytrHaX9V9OXGSWOejx7g5OsmOF/n12HSW6AEtMIStFTPtI hECM4Bg/4gh
A3RbRC0d1CI82jM9/iGC9G3/Kyek8/Xf0vO6SY6zHpMeFH8YX80ZE HHhPRrT86gBRRc0/OM0Xtj8DkcO5KBoKZYFV59wegE/fB8/dncCIhdRzflCQEnOZ /OkdBHus00tsKjGdE/NWS/nFRV3mcF3uEMPpsuQSSSD8E1tvi02dAA0/cf7sBz4o P6+HygCe4Y3YSM3oihJSkxtdei7HIP0XiL8jXbDRMACgVLPBx+5swi+mFxyamg+I N5pbOSUOPKvbmsBsi46RiQIDAQABo4ID2jCCA9YwPQYJKwYBBAGCNxUHBDAwLgYm KwYBBAGCNxUIg72/SIbntyuG1YMwqq9JhbDpfIFQgpjWR4fLpwoCAWQCAQMwJwYD VR0lBCAwHgYIKwYBBQUHAwQGCCsGAQUFBwMTBggrBgEFBQcDAjAOBgNVHQ8BAf8E BAMCBsAwMwYJKwYBBAGCNxUKBCYwJDAKBggrBgEFBQcDBDAKBggrBgEFBQcDEzA
Dec 16 19:57:20 mini_httpd[13003]: tp_acl_cp_user_get: 1489: Could not retrieve valid data from datapath for session '10.0.14.49'-'10.0.14.48'
Dec 16 19:57:20 mini_httpd[12987]: handle_read_timeout: 4226: child exit after 1 requests
Dec 16 19:57:20 mini_httpd[12988]: handle_read_timeout: 4226: child exit after 1 requests
Dec 16 19:57:20 mini_httpd[13005]: tp_acl_cp_user_get: 1489: Could not retrieve valid data from datapath for session '10.0.14.49'-'10.0.14.48'
Dec 16 19:57:20 mini_httpd[13006]: tp_acl_cp_user_get: 1489: Could not retrieve valid data from datapath for session '10.0.14.49'-'10.0.14.48'
Dec 16 19:57:21 mini_httpd[12993]: handle_read_timeout: 4226: child exit after 1 requests
Dec 16 19:57:21 mini_httpd[12992]: handle_read_timeout: 4226: child exit after 1 requests
Dec 16 19:57:21 mini_httpd[12995]: handle_read_timeout: 4226: child exit after 1 requests
Dec 16 19:57:21 mini_httpd[13002]: tp_acl_cp_user_get: 1489: Could not retrieve valid data from datapath for session '10.0.14.49'-'10.0.14.48'
Dec 16 19:57:22 mini_httpd[13009]: tp_acl_cp_user_get: 1489: Could not retrieve valid data from datapath for session '10.0.14.49'-'10.0.14.48'
Dec 16 19:57:23 mini_httpd[13012]: handle_request: 1794: got nothing, child exit after 0 requests
Dec 16 19:57:23 mini_httpd[13013]: tp_acl_cp_user_get: 1489: Could not retrieve valid data from datapath for session '10.0.14.49'-'10.0.14.48'
Dec 16 19:57:23 mini_httpd[13015]: handle_request: 1794: got nothing, child exit after 0 requests
Dec 16 19:57:23 mini_httpd[13014]: handle_request: 1794: got nothing, child exit after 0 requests
Dec 16 19:57:25 mini_httpd[13003]: handle_read_timeout: 4226: child exit after 1 requests
Dec 16 19:57:25 mini_httpd[13004]: handle_read_timeout: 4226: child exit after 1 requests
Dec 16 19:57:25 mini_httpd[13005]: handle_read_timeout: 4226: child exit after 1 requests
Dec 16 19:57:25 mini_httpd[13006]: handle_read_timeout: 4226: child exit after 1 requests
Dec 16 19:57:27 mini_httpd[13009]: handle_read_timeout: 4226: child exit after 1 requests
Dec 16 19:57:28 mini_httpd[13013]: handle_read_timeout: 4226: child exit after 1 requests
Dec 16 19:57:29 awc[1009]: awc_connect to 10.0.14.10
Dec 16 19:57:29 mini_httpd[13022]: handle_request: 1760: SSL_accept fail, child exit after 0 requests error:00000005:lib(0):func(0):reason(5)
Dec 16 19:57:30 mini_httpd[13024]: tp_acl_cp_user_get: 1489: Could not retrieve valid data from datapath for session '10.0.14.49'-'10.0.14.48'
Dec 16 19:57:30 syslog: process_msg_ref: 20: got msg_ref of len 10453 and body '/tmp/.cli_msg_zSL1rO'
Dec 16 19:57:30 syslog: process_msg_ref: 33: opening '/tmp/.cli_msg_zSL1rO'
Dec 16 19:57:30 syslog: process_msg_ref: 38: reading large msg
Dec 16 19:57:30 syslog: process_msg_ref: 41: read large msg of 10452 bytes
Dec 16 19:57:35 mini_httpd[13023]: handle_request: 1794: got nothing, child exit after 0 requests
Dec 16 19:57:39 mini_httpd[13030]: tp_acl_cp_user_get: 1489: Could not retrieve valid data from datapath for session '10.0.14.49'-'10.0.14.48'
Dec 16 19:57:39 syslog: process_msg_ref: 20: got msg_ref of len 11017 and body '/tmp/.cli_msg_T3cOyK'
Dec 16 19:57:39 syslog: process_msg_ref: 33: opening '/tmp/.cli_msg_T3cOyK'
Dec 16 19:57:39 syslog: process_msg_ref: 38: reading large msg
Dec 16 19:57:39 syslog: process_msg_ref: 41: read large msg of 11016 bytes
Dec 16 19:57:40 mini_httpd[13029]: tp_acl_cp_user_get: 1489: Could not retrieve valid data from datapath for session '10.0.14.49'-'10.0.14.48'
Dec 16 19:57:40 syslog: process_msg_ref: 20: got msg_ref of len 11482 and body '/tmp/.cli_msg_Ui0Zkb'
Dec 16 19:57:40 syslog: process_msg_ref: 33: opening '/tmp/.cli_msg_Ui0Zkb'
Dec 16 19:57:40 syslog: process_msg_ref: 38: reading large msg
Dec 16 19:57:40 syslog: process_msg_ref: 41: read large msg of 11481 bytes
Dec 16 19:57:43 mini_httpd[13037]: tp_acl_cp_user_get: 1489: Could not retrieve valid data from datapath for session '10.0.14.49'-'10.0.14.48'
