Connectivity problem when 2nd IAP is added to virtual controller
  • 1.  Connectivity problem when 2nd IAP is added to virtual controller
    Posted Jul 10, 2020 12:54 AM
    I have 2 IAPs - an IAP-105 and an IAP-215. They are both running 6.4.4.8-4.2.4.6_58505 for their respective WAP type. They both show up in the Virtual Controller interface.
    However, if I have both up, clients connected to either WAP cannot connect to the Internet, but the controller sees the client connected to the WAP. If I turn either one off, clients can immediately connect to the Internet to the other one.
    I am not sure where there can be a conflict. When I added the second WAP (the IAP-215), it autojoined and downloaded the config from the virtual controller, so it should not have a different config than the IAP-105.
    Any ideas?
  • 2.  RE: Connectivity problem when 2nd IAP is added to virtual controller
    Posted Jul 10, 2020 04:28 AM
    Configuration of IAPs would be helpful to check for the issue.
    Have you checked the Switch side? Are the ports configured different - saying are for instance VLANs missing on the second AP Port?
    Have you checked:
    sh ap debug auth-trace-buf
    sh log user
    sh log system
    This is something you have to run on the AP the Clients try to connect.
  • 3.  RE: Connectivity problem when 2nd IAP is added to virtual controller
    Posted Jul 10, 2020 03:54 PM
    I looked through all the configs, ran show tech, but didn't change anything and suddenly it started working! Maybe a cache cleared or something. And it's now working flawlessly. Go figure! Thanks to @cordless for inspiring me to double-check everything.
