Wired Intelligent Edge
last person joined: 8 hours ago
Connectivity problem with 2930F switch
  • 1.  Connectivity problem with 2930F switch
    Posted Jan 23, 2018 06:38 PM
    Hi guys,
    I am very new with Aruba switches and I have a problem with switch 2930F. I want to upgrade the firmware, the switch is new with the factory configuration. I have configured an IP address as:
    switch(config)#vlan 1 ip address 192.168.1.10 255.255.255.0
    Then I have configured in my laptop IP 192.168.1.2 255.255.255.0 and I have connected my laptop Ethernet port to switch port 1.
    In that way, I can ping from my laptop to the switch IP address, even I can telnet into it. But I can't ping from the switch to my laptop, and when I want to download the new firmware from my laptop through TFTP to do the upgrade, the switch console shows a connectivity error with 192.168.1.2.
    What could be the problem? Any ideas?
    On the other hand, is there any upgrade guide for this switch? I have browsed manuals HPE ArubaOS-Switch Management and Configuration Guide K/KA/KB.16.01 and HPE ArubaOS-Switch Advanced Traffic Management Guide K/KA/KB.16.01 and there's nothing about upgrade. The only thing I have found by googling is this
    https://community.spiceworks.com/how_to/82205-how-to-update-hp-switch-firmware
    and works well, but I would like to find any HP upgrade official guide.
    Julián
  • 2.  RE: Connectivity problem with 2930F switch
    Posted Jan 23, 2018 07:23 PM
    Do you have the windows firewall on?
    As far as upgrading you should be able to run this command (assuming you are running a tftp server on your laptop)
    copy tftp flash 192.168.1.2 (firmware file name).swi primary
    btw, this is an easy tftp server to get running https://tftpd64.codeplex.com/
  • 3.  RE: Connectivity problem with 2930F switch
    Posted Jan 24, 2018 12:07 AM
    Hi Robert,
    Good point, yes, I have the Windows firewall enabled. Tomorrow I will disable it and let you know.
    Thanks for TFTP server link, in fact it is the one I use!
    Thanks for the command for upgrading as well, I have just found a guide which includes the upgrading process (HPE ArubaOS-Switch Basic Operation Guide 16.02).
    Julián
  • 4.  RE: Connectivity problem with 2930F switch
    Posted Jan 25, 2018 02:27 PM
    Hi Robert,
    I have disabled the Windows firewall and the connectivity problem has gone, thank you very much.
    For the upgrading procedure I have been able to upgrade this switch (JL253A) using the procedure you explained, however, I haven't been able to upgrade my other switch (JL259A) to the same version. This is the output:
    SW-ACCESS1# copy tftp flash 10.115.70.10 WC_16_03_0007.swi primary
    The primary image will be deleted.
    Continue (y/n)? y
    020M
    Validating and Writing System Software to the Filesystem ...
    SW-ACCESS1# show flash
    Image Size (bytes) Date Version
    Primary Image : 20530856 10/26/16 WC.16.02.0014
    Secondary Image : 20530856 10/26/16 WC.16.02.0014
    Boot ROM Version
    Primary Boot ROM Version : WC.16.01.0003
    Secondary Boot ROM Version : WC.16.01.0003
    Default Boot Image : Primary
    Default Boot ROM : Primary
    SW-ACCESS1#
    I don't know but the new software is not loaded into the primary flash, but the console doesn't throw any error. I have tried with the secondary flash and with the same result.
    What could be the problem? Any workaround?
    Julián
  • 5.  RE: Connectivity problem with 2930F switch
    Posted Jan 25, 2018 04:29 PM
    Greetings!
    Are there any error messages displayed in the system log ('show log -r') related to the software image copy?
  • 6.  RE: Connectivity problem with 2930F switch
    Posted Jan 25, 2018 06:12 PM
    Hi Matthew,
    Thanks for your interest. I will try tomorrow that command and let you know.
    Julián
  • 7.  RE: Connectivity problem with 2930F switch
    Posted Jan 26, 2018 10:16 AM
    Hi Matthew,
    There is no error messages related to the TFTP transfer. This is what I see:
    I 01/01/90 04:46:28 00002 vlan: Gestion virtual LAN disabled
    I 01/01/90 04:46:28 00077 ports: port 24 is now off-line
    I 01/01/90 03:50:44 04244 update: User 'manager' : Secondary Image updated via
    TFTP from 10.115.70.10 completed.Firmware version: Before
    update: WC.16.02.0014 After update : WC.16.02.0014
    I 01/01/90 03:50:41 00163 update: Firmware image contains valid signature.
    I 01/01/90 03:50:40 00131 tftp: Transfer completed
    I 01/01/90 03:42:30 04244 update: User 'manager' : Primary Image updated via
    I 01/01/90 03:42:27 00163 update: Firmware image contains valid signature.
    I 01/01/90 03:42:26 00131 tftp: Transfer completed
    I 01/01/90 03:38:56 04244 update: User 'manager' : Primary Image updated via
    I 01/01/90 03:38:53 00163 update: Firmware image contains valid signature.
    I 01/01/90 03:38:52 00131 tftp: Transfer completed
    I 01/01/90 03:38:19 00179 mgr: SME SSH from 10.115.70.10 - MANAGER Mode
    Any idea?
    Julián
    Attachment(s)
    txt
    show_log_r.txt   11 KB 1 version
  • 8.  RE: Connectivity problem with 2930F switch
    Posted Jan 29, 2018 01:47 PM
    That is quite curious.  Have you tried re-downloading the WC.16.03.0007 image from the support site?  Alternately, I would suggest trying a different version (e.g., WC.16.04.0011) and seeing if you get the same result.  If so, I would recommend opening a support case so we can investigate the issue further.
