We are trying to get a Cisco 6880x to connect with an Aruba 3810M.
After connecting the fiber between them the link shows up with no errors, but the Aruba side shows transmit packets being dropped.
From the Aruba side LLDP and CDP shows info for the Cisco switches.
I have searched the internet for the past 2 days and had 3 others look at it and still cannot get it working.
Any help or insights are much appreciated.
Here are the configs for the Cisco and Aruba switches.
Cisco 6880 config
[IT-CORE1]
conf t
int lo0
ip add 1.1.1.1 255.255.255.255
vlan 99
name TEST
int te5/9.99
description TEST
encapsulation dot1Q 99
ip address 192.168.99.1 255.255.255.0
glbp 1 ip 192.168.99.3
glbp 1 priority 110
glbp 1 preempt
no shut
ip route 2.2.2.2 255.255.255.255 10.253.254.6
ip route 3.3.3.3 255.255.255.255 192.168.99.4
ip route 192.168.99.0 255.255.255.0 10.253.254.6
[IT-CORE2]
conf t
int lo0
ip add 2.2.2.2 255.255.255.255
vlan 99
name TEST
int te5/9.99
description TEST
ip address 192.168.99.2 255.255.255.0
glbp 1 preempt
no shut
ip route 1.1.1.1 255.255.255.255 10.253.254.5
ip route 192.168.99.0 255.255.255.0 10.253.254.5
[Aruba IGT Switch]
*Need interface vlan 99 created, IP 192.168.99.4 255.255.255.0
*Need 2 uplinks to Core SW’s tagged w/ vlan 99
*Need default route to 192.168.99.3
*Need loopback IP 3.3.3.3
Running configuration:
; hpStack_KB Configuration Editor; Created on release #KB.16.02.0013
; Ver #0e:01.b3.ff.7c.5f.fc.7b.ff.ff.fc.ff.ff.3f.ef:cb
stacking
member 1 type "JL072A" mac-address 00fd45-75b580
member 1 flexible-module A type JL083A
member 2 type "JL072A" mac-address 00fd45-75db80
member 2 flexible-module A type JL083A
exit
hostname "IGT-Aruba-Stack-3810M"
no rest-interface
fault-finder broadcast-storm sensitivity high
fault-finder bad-driver sensitivity high
fault-finder bad-transceiver sensitivity high
fault-finder bad-cable sensitivity high
fault-finder too-long-cable sensitivity high
fault-finder over-bandwidth sensitivity high
fault-finder loss-of-link sensitivity high
fault-finder duplex-mismatch-hdx sensitivity high
fault-finder duplex-mismatch-fdx sensitivity high
fault-finder link-flap sensitivity high
mesh 1/A1,1/A4,2/A1,2/A4
mesh id 3
port-security 1/A2 learn-mode configured
port-security 2/A3 learn-mode configured
ip default-gateway 192.168.99.3
ip route 0.0.0.0 0.0.0.0 192.168.99.3
ip route 10.190.1.0 255.255.255.0 10.190.253.1
ip route 172.16.61.0 255.255.255.0 172.16.61.253
ip route 172.16.62.0 255.255.255.0 172.16.62.253
ip routing
interface loopback 1
ip address 3.3.3.3
exit
snmp-server community "public" unrestricted
snmp-server location "IGT Rack"
oobm
ip address dhcp-bootp
member 1
exit
member 2
exit
exit
vlan 1
name "DEFAULT_VLAN"
no untagged 1/2-1/48,1/A2,2/1-2/48,2/A3
untagged 1/1,1/A3,2/A2
tagged Mesh
no ip address
exit
vlan 2
name "VLAN2"
tagged 1/10-1/12,1/16-1/18,2/13-2/18,Mesh
ip address 172.19.0.249 255.255.0.0
exit
vlan 18
name "VBC"
ip address 172.18.100.255 255.255.0.0
exit
vlan 61
name "LBC1"
ip address 172.16.61.254 255.255.255.0
exit
vlan 62
name "LBC2"
ip address 172.16.62.254 255.255.255.0
exit
vlan 63
name "Bonus"
no ip address
exit
vlan 65
name "Floor"
no ip address
exit
vlan 66
name "Domain"
ip address 10.190.166.254 255.255.255.0
exit
vlan 99
name "TEST"
tagged 1/A2,2/A3,Mesh
ip address 192.168.99.4 255.255.255.0
ip igmp
exit
vlan 100
name "DEFAULT-VLAN"
untagged 1/2,1/6-1/9,1/21-1/23,1/25-1/48,2/1-2/2,2/6-2/9,2/21-2/23,2/25-2/48
tagged Mesh
ip address 192.168.100.1 255.255.255.0
exit
vlan 101
name "Storage"
untagged 1/3-1/5,1/19-1/20,1/24,2/3-2/5,2/19-2/20,2/24
tagged Mesh
no ip address
exit
vlan 102
name "vMotion"
untagged 1/13-1/15,2/10-2/12
tagged Mesh
no ip address
exit
vlan 253
name "CORE"
tagged Mesh
ip address 10.190.253.4 255.255.255.0
exit
primary-vlan 100
spanning-tree Mesh priority 0
no spanning-tree bpdu-throttle
