Connectivity problems with iPads and overall capacity problems Mesh environment
  • 1.  Connectivity problems with iPads and overall capacity problems Mesh environment
    Posted Dec 20, 2013 09:02 AM
    Three buildings.
    First one is connected to the second one by two 134 AP, the second one is connected to the third one by two 105 AP
    In all these 3 buildings are 105's. Both PTP connections in MESH mode (portal-point)
    iPads have connectivity problems in the second building even there are capacity problems in this second building
    Two 650 installed in the first building., last version 6.1.3.7
  • 2.  RE: Connectivity problems with iPads and overall capacity problems Mesh environment
    Posted Dec 20, 2013 09:18 AM
    Are the APs installed in the buildings and are trying to create mesh links through the walls? Could you give us the output of the command:
    #show ap mesh topology
  • 3.  RE: Connectivity problems with iPads and overall capacity problems Mesh environment
    Posted Dec 23, 2013 03:09 AM
    I added out of GUI these Mesh Links and drawing
  • 4.  RE: Connectivity problems with iPads and overall capacity problems Mesh environment
    Posted Dec 24, 2013 05:55 AM
  • 5.  RE: Connectivity problems with iPads and overall capacity problems Mesh environment
    Posted Dec 20, 2013 09:31 AM
    It could be a mesh issue, you should look at that first.  If you can test performance of the mesh links with IPerf on the wired side to eliminate that.
    Generally AP105's are not well suited for point to point mesh.  Probably need more details on the antennas being used for the 134 link.
    Once you verify you have solid and good mesh links with a wired to wired performance test
    If you're getting packet loss and poor performance on the mesh links, you'll need to look at a product better suited for mesh, like the MST200 or fix the mesh links.
    If mesh is soild and no packet loss or performance issues...
    - Check your min tx level in your ARM profile
    - look at the EIRP the AP's are running at
    - if your EIRP is equal to the Min tx level you have too much CCI (lower the min tx level)
    for example, if your min tx level is 9 and all your 2.4 radios are running at 9, then you have too much coverage and you need to lower the min tx level to 6
    if your min tx level is 9 and all your APs are running at 20+ you don't have enough coverage and need to add more APs
    You also need to get on current code. 6.1 is at its end of development,
  • 6.  RE: Connectivity problems with iPads and overall capacity problems Mesh environment
    Posted Dec 20, 2013 12:48 PM
    Hi Alan,
    Thanks for your feedback..
    I have a challenge ;-)
    I will come back to you later on this
    Peter
  • 7.  RE: Connectivity problems with iPads and overall capacity problems Mesh environment
    Posted Dec 23, 2013 03:54 AM
    Some stats and placement of 134 and ARM included
