For ClearPass 500 , what is Console Cable type ( nrmal or null ) & what are needed settings Console settings ?
Using the null modem cable provided, connect a serial port on the appliance to a terminal, then connect power and
switch on. The appliance immediately becomes available for configuration.
Use the following parameters for the serial port connection:
l Bit Rate: 9600l Data Bits: 8
l Parity: Nonel Stop Bits: 1l Flow Control: None
