Wired Intelligent Edge
last person joined: 9 hours ago
Console Connection Issue - 2620 Switch
  • 1.  Console Connection Issue - 2620 Switch
    Posted Jan 26, 2022 08:39 AM
    I have a number of 2620 switches in production that I'm looking to setup remote access to via the console port.
    Of the 8 switches, I can only get a working console connection on 4. I'm using the same console cable, laptop, terminal settings on all switches.
    The only difference I have noticed between the working switches and the non-working switches is when I run a 'show session-list' command.
    On a working switch the 'Privilege' is set to 'Manager':
    But on a non-working switch the 'Privilege' is set to either 'Superuser' or is blank:
    My question is, do you know how I can set the 'Privilege' level for the console port, so I can try setting it to 'Manager' on the non-working switches to see if it fixes my issue?
    Adam Bishop
