Wired Intelligent Edge
Console connection to CX switch using micro usb not works
This thread has been viewed 210 times
  • 1.  Console connection to CX switch using micro usb not works
    Posted Apr 29, 2021 08:20 AM
    Edited by MT80 Apr 29, 2021 08:20 AM
    Hello everyone,
    I'm try connect my Windows 10 computer to Aruba CX 8325 via micro usb console cable. I use default Aruba settings for this connection  on Putty -->
    I can't connect to switch.
    When I try connect with the same computer and the same cable to Aruba OS it is works.
    OS on Aruba 8325 is GL.10.06.0010.
    Console cable witch RJ45  works correct.
    Do you have any ideas what can be wrong ?
  • 2.  RE: Console connection to CX switch using micro usb not works
    Posted Apr 29, 2021 08:48 AM
    Have you checked device manager to see if the COM port changed to something other than COM1 when connected to the CX switch?
    Dustin Burns
  • 3.  RE: Console connection to CX switch using micro usb not works
    Posted Apr 29, 2021 09:08 AM
    Edited by MT80 Apr 29, 2021 09:10 AM
    Yes, I have chosen appropriate com port for the connection :)
  • 4.  RE: Console connection to CX switch using micro usb not works
    Posted Apr 29, 2021 09:27 AM
    Hmm , and nothing after hitting enter a few times?
    Dustin Burns
  • 5.  RE: Console connection to CX switch using micro usb not works
    Posted Apr 29, 2021 10:00 AM
    Just right, I choose appropriate com port, speed etc and after it type enter and nothing. I have also the second 8325 CX switch and the same situation.
    Michał Turtoń
  • 6.  RE: Console connection to CX switch using micro usb not works
