Wired Intelligent Edge
Console doesn't work on EVE-NG Community Edition
This thread has been viewed 46 times
  • 1.  Console doesn't work on EVE-NG Community Edition
    Posted Jan 27, 2022 04:38 PM
    Hi Everyone,
    I'm working with eve-ng community edition installed on a Vsphere to build a cx lab using 10.09.
    I can connect the console of any device but the CX.
    I found and followed many suggestions here. No success.
      I can see that through html5, the guacamole establishes the connection (when I turn de cx off, connection is interrupted)
      I can see that through native, connection is also established (telnet my other doubt though).
      Is there anything that could prevent me to connect to the CX console?
      Will the CX accept telnet connection?
      MAURICIO LOPES
    • 2.  RE: Console doesn't work on EVE-NG Community Edition
      Posted Jan 28, 2022 04:09 AM
      Hi Mauricio.
      Try to connect mgmt port to external Net cloud and see, if switch will get an ip address from dhcp server.
      I use native console on 10.09 with no problems. Telnet connection to console works just fine. I have EVE-NG community on vmware.
      Best, Gorazd
      Gorazd Kikelj
    • 3.  RE: Console doesn't work on EVE-NG Community Edition
      Posted Feb 17, 2022 09:31 AM
      Thank you!
      I was trying in two virtualization layers environment. Now that I installed EVE-NG directly on top of L0 hypervisor, it's working fine!
      MAURICIO LOPES
    • 4.  RE: Console doesn't work on EVE-NG Community Edition
      Posted Jan 28, 2022 04:04 PM
      Sometime it is just an HTML5 issue. Minimize console, click on console on other node, restore console windows and type twice ENTER.
      Vincent Giles
