Console Port on AP-515 no response?
This thread has been viewed 120 times
  • 1.  Console Port on AP-515 no response?
    Posted Mar 12, 2020 10:07 AM
    I tried to use the console port of my new AP-515 Access points but my PC (win10) does not recognize anything if I plug in the USB Micro Cable to the access point.
    Do I have to enable the console port somewhere ?
    The AP run as Instant APs
  • 2.  RE: Console Port on AP-515 no response?
    Posted Mar 12, 2020 10:15 AM
    That AP requires a special cable  .  Some have obtained it on Amazon.  Please see here:  https://community.arubanetworks.com/t5/Controllerless-Networks/IAP-345-USB-to-MicroB-Console-Cable/td-p/425764
  • 3.  RE: Console Port on AP-515 no response?
    Posted Mar 12, 2020 11:18 AM
    Hi jJoseph,
    thanks you for the Information....
    I can't beleive that in the days of USB Standards, Aruba uses an own pinout...but well...I ordered a cable at Amazon...(shaking the head)
  • 4.  RE: Console Port on AP-515 no response?
    Posted Mar 12, 2020 11:21 AM
    In the same thread Onno Harms explains why.
  • 5.  RE: Console Port on AP-515 no response?
    Posted Oct 15, 2020 05:30 AM
    hello
    One of my. customer has the official console cable JY728A
    Parameters on terminal are ;
    9600 baud,
    8 bits,
    no parity,
    1 stop bit,
    no flow control,
    no carrier watch
    He did a power cycle of the AP and still no output on the console...
    We plan to ship a new cable but anay other idea will be appreciated.
    regards
    Olivier
  • 6.  RE: Console Port on AP-515 no response?
    Posted Oct 15, 2020 11:15 AM
    Sorry to ask, but making sure: did the customer install the driver, resulting in an active COM port when the cable is plugged in?
  • 7.  RE: Console Port on AP-515 no response?
    Posted Aug 17, 2021 10:17 AM
    I've downloaded this driver from ASP, but there are no release notes, no instructions, and no .exe files in the Zip. Can anyone help us with this?
    Brian Simpson
  • 8.  RE: Console Port on AP-515 no response?
    Posted Aug 24, 2021 09:20 AM
    These days it is barely needed to manually install drivers, so if you are not a long term Windows user (I'm feeling old ;-), you may not be familiar with the procedure.
    Go in the Device Manager, from there find the unrecognized device under the 'Other Devices' and with the yellow warning sign on top of it, open properties for that device, click 'Update Driver', then 'Browse my computer for drivers' and point to the directory/folder where you extracted the ZIP file you downloaded.
    That is the directory where you have the .inf files (ftdibus.inf and ftdiport.inf). From there it should recognize the device and install the drivers.
  • 9.  RE: Console Port on AP-515 no response?
    Posted Aug 30, 2021 11:28 AM
    Thanks Herman, that was perfect. I am up and running.
    Brian Simpson
  • 10.  RE: Console Port on AP-515 no response?
    Posted Oct 09, 2023 04:41 AM
    @Benedikt Geltenpoth
    Hello dear , did you fix your problem?
