Wired Intelligent Edge
Console to USB cable recommendations
  • 1.  Console to USB cable recommendations
    Posted Apr 03, 2014 06:47 AM
    Hi Everyone
    I have just started with a company that has numerous HP Procurve Switch 2650 but unfortunately no one knows where the console cables are or if we still have them.
    so i am hopping someone can recommend USB to RS232, think that is what i need and all our laptops are USB.
    I do not really have much experience with HP but can i use putty to connect to the HP switch through the RS232 cable?
    Putty setup
    COM1
    baud rate 9600
    8 data bits
     1 stop bit
    no parit
    flow control set to Xon/Xoff
    any help would be really appreceated
    Thanks in advacne............
    Ps where the best place to learn about VLANs. untagging, tagging etc?
    #putty
  • 2.  RE: Console to USB cable recommendations
