Consolidated list Channel utilization & Busyness through cli.
  • 1.  Consolidated list Channel utilization & Busyness through cli.
    Posted Mar 31, 2017 03:17 PM
    Though dashboard --> Access points, we see the lot more information consolidated in the best possible way.
    However there are certain fields which I don't find any means to obtain through cli, like the ones of seeing "channel utilization", "Channel Quality", "Channel busy"....
    Wanted to see the confirmation from TAC if there's a possible way to obtain this information from the cli as well?
  • 2.  RE: Consolidated list Channel utilization & Busyness through cli.
    Posted Mar 31, 2017 03:24 PM
    Do you have airwave?
    Get Outlook for iOS
  • 3.  RE: Consolidated list Channel utilization & Busyness through cli.
    Posted Mar 31, 2017 03:45 PM
    The airewave is likely to be in our network few months down the line.
    Through controller cli, is it not possible to see the informaion that has been reflected through gui.
    I am specificially looking for info like: "channel utilization"/ "Channel Quality"/"Channel busy" for all the associated APs.
  • 4.  RE: Consolidated list Channel utilization & Busyness through cli.
    Posted Mar 31, 2017 04:58 PM
    Not via CLI unfortunately
  • 5.  RE: Consolidated list Channel utilization & Busyness through cli.
  • 6.  RE: Consolidated list Channel utilization & Busyness through cli.
    Posted Apr 01, 2017 05:26 AM
    Thanks Joseph for the prompt response.
    I could see channel utilization and interference. However appears the volume of consolidated information captured via gui is not possible throught cli.
    (IDC_WLC_PR_0002) #show ap radio-summary ip-addr 172.25.44.46
    APs Radios information
    Name                      Group    AP Type  IP Address    Band  Mode     EIRP/MaxEIRP  NF/U/I     TD           TM                 TC
    P-CT1L22-D3PO-T-OAP-0002  NPP-CT1  277      172.25.44.46  5     MP::36   15/28.5       -97/38/2   4/4/4/4/4/4  25/26/26/25/26/24  1/0/0/0/0/0
    P-CT1L22-D3PO-T-OAP-0002  NPP-CT1  277      172.25.44.46  2.4   AP:HT:1  15/30.5       -97/53/17  1/1/1/1/1/2  24/23/21/23/24/25  0/0/0/1/0/0
    NF: Noise Floor(dBm); U: Utilization(%); I: Interference(%)
    Mode: HT or VHT mode followed by Key Word "SCH" indicates that single chain mode is enabled on this radio
    TD/TM/TC(*/*/*/*/*/*): "*" is the time used by Data/Mgmt/Ctrl Frames(%) in a 10 seconds time slot in the past 1 minute
    AP followed by "^" indicates that spectrum monitoring is enabled on the radio in AP mode
    Total Radios:2
  • 7.  RE: Consolidated list Channel utilization & Busyness through cli.
    Posted Apr 01, 2017 06:02 AM
    It does not match it exactly, no.  The commandline provides information at that time, and not charts and graphs.  What other information did you want?
  • 8.  RE: Consolidated list Channel utilization & Busyness through cli.
    Posted Apr 08, 2017 10:04 AM
    Obviously, its not expected the information in cli be represented in the way its done via gui( charts and graphs) :)
    I was rather asking for the means to know the variety of info that is seen in GUI, can it be seen throught cli?
    For instance, channel utilization and interference can be captured in "show ap radio-summary".
    However there are other infos like:
    SNR, Goodput, Health, Channel Quality, Channel busy ..
    Which I fail to find though cli's.
    Please correct me if I am missing something.
  • 9.  RE: Consolidated list Channel utilization & Busyness through cli.
    Posted Apr 08, 2017 04:23 PM
    SNR of clients is in "show ap association"
    Goodput and Health only show up in the GUI and are synthetic measurements.
    Channel Busy is the same as channel utilization.
  • 10.  RE: Consolidated list Channel utilization & Busyness through cli.
    Posted Apr 16, 2017 06:04 AM
    Thanks Joseph.
    Could obtain the SNR from the cli you recommended. Is there any cli to obtain the RSSI of client as well?
    (WLC002) #show ap association client-mac 18:4f:32:f2:ba:ef
    The phy column shows client's operational capabilities for current association
    Flags: A: Active, B: Band Steerable, H: Hotspot(802.11u) client, K: 802.11K client, M: Mu beam formee, R: 802.11R client, W: WMM client, w: 802.11w client V: 802.11v BSS trans capable
    PHY Details: HT   : High throughput;      20: 20MHz;  40: 40MHz; t: turbo-rates (256-QAM)
                 VHT  : Very High throughput; 80: 80MHz; 160: 160MHz; 80p80: 80MHz + 80MHz
                 <n>ss: <n> spatial streams
    Association Table
    Name                              bssid              mac                auth  assoc  aid  l-int  essid    vlan-id  tunnel-id  phy              assoc. time  num assoc  Flags  Band steer moves (T/S)
    AP                                 40:e3:d6:18:cf:38  18:4f:32:f2:ba:ef  y     y      1    10     AP-S      167      0x10497    a-VHT-20sgi-2ss  1m:12s       1          WAB    38/15
    18:4f:32:f2:ba:ef-40:e3:d6:18:cf:38 Stats
    Parameter                            Value
    Channel                              40
    Channel Frame Retry Rate(%)          0
    Channel Frame Low Speed Rate(%)      0
    Channel Frame Non Unicast Rate(%)    0
    Channel Frame Fragmentation Rate(%)  0
    Channel Frame Error Rate(%)          0
    Channel Bandwidth Rate(kbps)         0
    Channel Noise                        0
    Client Frame Retry Rate(%)           0
    Client Frame Low Speed Rate(%)       0
    Client Frame Non Unicast Rate(%)     0
    Client Frame Fragmentation Rate(%)   0
    Client Frame Receive Error Rate(%)   0
    Client Bandwidth Rate(kbps)          0
    Client Tx Packets                    376
    Client Rx Packets                    63
    Client Tx Bytes                      18206
    Client Rx Bytes                      8822
    Client SNR                           31
    A2c_SM SeqNum, Old SeqNums           120809 0
