Consoling into AP275
  • 1.  Consoling into AP275
    Posted Dec 29, 2014 12:27 PM
    I'm having trouble consoling into an AP275.  I've downloaded the suggested drivers but still no luck any suggestions?
  • 2.  RE: Consoling into AP275
    Posted Dec 29, 2014 01:41 PM
    Hi Friend,
    I believe, you are using the correct USB cable ( Micro USB )
    Please download the file " CP210x_VCP_Win2K_XP_S2K3.zip " from the support site.
    you can use the following link :
    http://support.arubanetworks.com/ToolsResources/tabid/76/DMXModule/514/Command/Core_Download/Default.aspx?EntryId=4230
    Install the drivers, on succesfull installation you should be able to see the following,
    For your ref :
    Hope your issue will be solved,
    Please feel free for any further help on this.
  • 3.  RE: Consoling into AP275
    Posted Jan 02, 2015 04:11 PM
    i got some truble when consoling to IAP 275 too , especialy when i try to reset it.
    i was using the correct driver.
  • 4.  RE: Consoling into AP275
    Posted Feb 12, 2015 11:38 AM
    My fix was setting flow control to "none" on my putty session.
