Contains vs equal clearpass policy Manager
This thread has been viewed 30 times
  • 1.  Contains vs equal clearpass policy Manager
    Posted May 16, 2014 10:15 AM
    Hello
    I was budling a rule just now as i was preparing a demo... and i was stuck for a whole 10 minutes
    I got a group in AD which the name is Ingenieria
    So i was building a rule which says  member of EQUALS Ingenieria... it didnt work...
    But as soon as i changed to this CONTAINS it worked...
    polciymanager.JPGWhats the difference????
    As far i knew the EQUALS its like that  Equals.. it was looking for a group in Active directory with that same name...
    Contains would be a AD group that contains that word Ingenieria...
    I am wrong? if so can you guys enligh me with this???
    Cheers
    Carlos
  • 2.  RE: Contains vs equal clearpass policy Manager
    Posted May 16, 2014 10:17 AM
    Equals means it solely contains that single, unique value. Since memberof may have multiple values, you need to use Contains.
  • 3.  RE: Contains vs equal clearpass policy Manager
    Posted May 16, 2014 10:27 AM
    So basically on member of you always have to use contains?You never use Equals?
    Cheers
    Carlos
  • 4.  RE: Contains vs equal clearpass policy Manager
    Posted May 16, 2014 10:29 AM
    Yes, I always contains.
  • 5.  RE: Contains vs equal clearpass policy Manager
    it just that as im referring to a group name  for me it has a single unique value... the only name it has which in this case is Ingenieria...
    Thats why i dont understand...
    Cheers
    Carlos
  • 6.  RE: Contains vs equal clearpass policy Manager
    Posted May 16, 2014 10:30 AM
    For memberof...ALWAYS use contains.  EQUALS will never hit as you would need to match on the entire string returned from AD
  • 7.  RE: Contains vs equal clearpass policy Manager
    Posted May 16, 2014 10:55 AM
    Edit.
  • 8.  RE: Contains vs equal clearpass policy Manager
    Posted May 17, 2014 11:14 AM
    For the memberOf, you need to use Contains; if you use the Groups propery, you can use EQUALS:
    (Authorization:dc-02.nl:Groups  EQUALS  Domain Admins)
    Personally I tend use Groups, instead of memberOf as it makes a more thorough match.
  • 9.  RE: Contains vs equal clearpass policy Manager
    MVP
    Posted May 20, 2014 10:16 AM
    How is Groups better than memberOf? BTW, for more exact a more exact match, you need to use a fully path with memberOf like
    (Authorization:SENSENET Domain:memberOf  CONTAINS  CN=Staff,OU=Security Groups,OU=IS,OU=FSA,DC=University,DC=liberty,DC=edu
    If you use (Authorization:SENSENET Domain:memberOf  CONTAINS  Staff) it would match any group that contains the string "Staff" and any group in a path that contains "Staff".
    What is the behavior of using "Groups EQUALS"?
  • 10.  RE: Contains vs equal clearpass policy Manager
    Posted May 20, 2014 10:32 AM
    In your example, memberOf  CONTAINS  CN=Staff,OU=Security Groups,OU=IS,OU=FSA,DC=University,DC=liberty,DC=edu is indeed a complete match.
    And that is functionally equal to Groups EQUALS Staff (which is much shorter).
    Where lies a possible issue is like in the question where memberOf CONTAINS Ingenieria. In that case, CN=Disabled-Users,OU=Ingeniera,DC=domain,DC=com will match.
    Groups EQUALS Ingeniera is exactly what does what is expected in this question; and seems better for overview  to me in most cases. This does not match anything else than the group name Ingeniera.
    So I prefer to use the Group EQUALS variant as it better matches the expectations that many users have and for that reason avoids errors.
    Herman
  • 11.  RE: Contains vs equal clearpass policy Manager
    Posted Feb 15, 2021 08:20 PM
    Herman,
    I know this is a super old thread. In my ClearPass 6.9 I don't seem to pull down a group attribute on authentication to validate the group name equals. Here is what I see to validate against. Any idea if I am missing something to put down the group name? I had an issue where two member of names were similar and contains threw me for a loop when it was put in the wrong policy.
    Thanks!
    Christopher Calhoun
  • 12.  RE: Contains vs equal clearpass policy Manager
    Posted Feb 16, 2021 04:50 AM
    Just add a check on 'Groups EQUALS' and the Groups will (likely) show up in Access Tracker. If attributes are not used during role-mapping or enforcement, they may not be retrieved as a performance optimization.
  • 13.  RE: Contains vs equal clearpass policy Manager
    Posted Feb 16, 2021 07:23 AM
    Makes perfect sense I will give it a try today in my Lab. Will let you know how it goes.
    Chris
    Christopher Calhoun
  • 14.  RE: Contains vs equal clearpass policy Manager
    Posted Feb 16, 2021 07:50 AM
    Thanks so much Herman. This has plagued me since the beginning of installing ClearPass. I guess I should have asked earlier. Now I can do Equals and not have to worry about similar names in the first applicable selections.
    There it is!
    Christopher Calhoun
