Content Length Exceed Limit
  • 1.  Content Length Exceed Limit
    Posted Apr 24, 2016 09:44 AM
    Hi all,
    I am trying to upgrade Aruba 650 from ArubaOS 6.1.3.7 to ArubaOS 6.4.3.7 via WebUI.
    But I received the error "Content Length Exceed Limit".
    The problem is that the size of the image is 72Mb and the size of nonboot partition /dev/mtdblock9 is only 50Mb.
    Is it possible somehow to extend partition /dev/mtdblock9 or to upgrade from external storage?
    (Aruba650) (config) #show storage
    Filesystem          Size      Used   Available Use%  Mounted on
    /dev/mtdblock11 156.0M 62.5M 93.5M      40%    /flash
    none                   300.0M 3.0M   297.0M    1%      /tmp
    /dev/mtdblock9   50.0M   24.8M 25.3M      50%    /mnt/img0
    /dev/mtdblock10 50.0M   24.5M 25.5M      49%    /mnt/img1
    (Aruba650) (config) #show image version
    Partition :                   0:0 (/dev/mtdblock9)
    Software Version :     ArubaOS 6.1.3.5 (Digitally Signed - Production Build)
    Build number :           35523
    Label :                       35523
    Built on :                    Fri Sep 28 07:46:05 PDT 2012
    Partition : 0:1 (/dev/mtdblock10) **Default boot**
    Software Version :     ArubaOS 6.1.3.7 (Digitally Signed - Production Build)
    Build number :           37112
    Label :                       37112
    Built on :                    Fri Feb 8 18:08:20 PST 2013
    Thank You
    Best regards,
    Nadiia Kotelnikova
  • 2.  RE: Content Length Exceed Limit
    Posted Apr 24, 2016 09:48 AM
    The problem is that the 650 has limited memory. Go to Maintenence> Files and delete as many files as possible (except your startup config) to see if you can free up enough room.
  • 3.  RE: Content Length Exceed Limit
    Posted Apr 24, 2016 12:25 PM
    Thank You for helping me! Everithing working correct!
    1) I deleted all files except default.cfg.
    2) Copied image via tftp:
    (hostname)# copy tftp: <tftphost> <image filename> system: partition <0|1>
    3) Rebooted the controller:
    (hostname)# reload
