control plane security disable
  • 1.  control plane security disable
    Posted Aug 21, 2014 01:06 PM
    adding a new local controller that is a 7220 running 6.4.2 and I cannot disable Control PLane Security. Its greyed out. I am thinking this is why I cannot see the new local from the Master. Any ideas?
    #7220
  • 2.  RE: control plane security disable
    Posted Aug 21, 2014 01:14 PM
    Is CPSec enabled on Master? Do you have the same code on every controller?
  • 3.  RE: control plane security disable
    Posted Aug 21, 2014 01:15 PM
    No and yes :)
  • 4.  RE: control plane security disable
    Posted Aug 21, 2014 01:17 PM
    It is disabled on the Master and they are all running 6.4.2
  • 5.  RE: control plane security disable
    Posted Aug 21, 2014 01:19 PM
    - Control Plane Security is enabled/disabled at the master
    - You cannot enable/disable it at the local
    - If the local never contacted the master, either because of a bad PSK or other reasons, it will not show up in the master, AND you will not be able to change the Control Plane Security Status.
  • 6.  RE: control plane security disable
    Posted Aug 21, 2014 01:23 PM
    well when I setup the 7200 I entered the IP and MAC of the master in there but it never shows up in the Master
  • 7.  RE: control plane security disable
    Posted Aug 21, 2014 01:31 PM
    It is supposed to be the ip address and a preshared key, NOT the MAC of the master:
    Please see here:  http://www.arubanetworks.com/techdocs/ArubaOS_63_Web_Help/Web_Help_Index.htm#ArubaFrameStyles/Adding_Local_Switches/Moving_to_a_Multi__Envir.htm on how to configure a PSK for a local controller and a master controller.
  • 8.  RE: control plane security disable
    Posted Jan 16, 2015 09:36 AM
    Thanks for level of detail. I performed the inital controller steps and it didn't work using the mac address of the master. Instead, used your notes and it worked!
    Thanks!
    D
