  • 1.  Controller
    Posted Nov 14, 2014 06:52 AM
    I have a Aruba 600 controller, which act as a master.Now i want to install another controller in the same network. [for testing purpose]
    My question is
    1. does the 2nd controller import all configuraton from master?
    2. I dont want to define it as local, if i dont is there any problem?
    3.  There is one dhcp server in the network, so i want to give the controller and ap [which i'm               going to implement with 2nd controller]  both static ip,
          and in ap i think to define the 2nd controller as a master controller, so from where this ap will        import configuration?
  • 2.  RE: Controller
    Posted Nov 14, 2014 07:02 AM
    You can leave as standalone if you don't wanted attached to your production controller.
    Make sure that you disable ADP so your APs dont try to join that controller in a reboot/bootstrapping event
    adp discovery disable
    adp igmp-join disable
    For your testing APs , I suggest you create a new VLAN and use DHCP option 43 to discover the controller
    http://www.arubanetworks.com/techdocs/ArubaOS_60/UserGuide/DHCP_Option_43.php
  • 3.  RE: Controller
    Posted Nov 14, 2014 07:13 AM
    ok victor , now the cenario is
    1st controller is master.
    2nd controller is in standalon.
    now if i configure roles in 2nd controller, does it make any effect on master?
    and also what is the command if i want again to turn on adp & igmp in ap...
  • 4.  RE: Controller
    Posted Nov 14, 2014 07:17 AM
    It won't because these are not talking to each other , any config you put in place in either controller will not be share
  • 5.  RE: Controller
    Posted Nov 14, 2014 07:18 AM
    To turn on adp on the test controller again use the same command but instead of disable use enable.
    Don't turn it off in your production controller just on test controller
  • 6.  RE: Controller
    Posted Nov 14, 2014 07:25 AM
    Thank you Victor
  • 7.  RE: Controller
    Controllers are different from Instant. In order to utilize the same configuration and be able to terminate APs, you'll have to add it as a local. Your other option would be to take a backup and then restore but I would not put them on the same subnet.
