Controller 620 is not providing the DHCP service !!!
  • 1.  Controller 620 is not providing the DHCP service !!!
    Posted May 29, 2014 07:11 AM
    I am using controller 620. Controller is on by default VLAN 1 with IP 172.16.0.254. I have make the DHCP server of this network and DHCP service is check in but still i am not able to get the IP address from the Controller
    My PC is attached to the controller port  0 then 1 then 2 and so on ....but still i am not getting IP via DHCP.
    Kindly help me in this regard.
  • 2.  RE: Controller 620 is not providing the DHCP service !!!
    Posted May 29, 2014 07:45 AM
    In addition to the scope, did you do this command?
    service dhcp
  • 3.  RE: Controller 620 is not providing the DHCP service !!!
    Posted May 29, 2014 08:01 AM
    I have applied the service DHCP command. Now its getting DHCP. but after sometime controller stop providing DHCP service
  • 4.  RE: Controller 620 is not providing the DHCP service !!!
    Posted May 29, 2014 08:17 AM
    Do you mean it won't give out additional IPs after some time?
    Please share each of the following:
    show vlan
    show ip interface brief
    show ip dhcp database
  • 5.  RE: Controller 620 is not providing the DHCP service !!!
    Posted May 29, 2014 08:23 AM
    Aruba620) #show vlan
    VLAN CONFIGURATION
    VLAN Description Ports AAA Profile
    1 Default FE1/0-7 GE1/8 Pc0-7 N/A
    (Aruba620) #show ip interface brief
    Interface IP Address / IP Netmask Admin Protocol
    vlan 1 172.16.0.254 / 255.255.255.0 up up
    loopback unassigned / unassigned up up
    mgmt unassigned / unassigned down down
    (Aruba620) #show ip dhcp database
    DHCP enabled
    # default-pool
    subnet 172.16.0.0 netmask 255.255.255.0 {
    default-lease-time 616;
    max-lease-time 616;
    option domain-name-servers 8.8.8.8;
    option routers 172.16.0.254;
    range 172.16.0.1 172.16.0.253;
    authoritative;
    (Aruba620) #show ip dhcp binding
    lease 172.16.0.1 {
    starts epoch 1401365478; # Thu May 29 17:11:18 2014
    ends epoch 1401366094; # Thu May 29 17:21:34 2014
    cltt epoch 1401365478; # Thu May 29 17:11:18 2014
    binding state active;
    next binding state free;
    hardware ethernet a4:5d:36:c9:3f:e7;
    However my system get the IP from DHCP and after sometime IP parameters are disappeared, but on controller it is showing DHCP binding. Same issue on different laptops, Desktops.
  • 6.  RE: Controller 620 is not providing the DHCP service !!!
    Posted May 29, 2014 08:33 AM
    It looks like you have your lease set for about 10 minutes, is that right?     Do you have the port trusted or is your device getting a role when attached.  Also, what version of code are you running?   Please share the following too.
    show ip dhcp statistics
    show port status
    show user (when device is attached)
    If the device shows in the user table, run the following:
    show rights <role the user in above>
  • 7.  RE: Controller 620 is not providing the DHCP service !!!
    Posted May 30, 2014 12:21 AM
    You are right !!! The DHCP lease was set to 10mins and 60secs. Now i set the DHCP service Lease time for VLAN 1 & 2 is 0days 0hours, 0mins and 0secs. But Show user and show user table didnot show any entity in the table.
    (Aruba620) #show ip dhcp statistics
    DHCPv4 enabled; DHCPv6 disabled
    DHCP Pools
    Network Name  Type  Active  Configured leases  Active leases  Free leases  Expir
    ed leases  Abandoned leases
    default-pool  v4    Yes     253                1              252          0
               0
    Test          v4    Yes     0                  -              -            -    -
    Current leases          253
    Total leases            256
    NOTE: To make a DHCPv6 pool active, ensure that the pool name is added in vlan interface
    vlan 2                     192.168.2.1 / 255.255.255.0     up      down
    (Aruba620) #show port status
    1/0        FE        Enabled     Down       Enabled  Yes      Disabled      Access
    1/1        FE        Enabled     Down       Enabled  Yes      Disabled      Access
    1/2        FE        Enabled     Down       Enabled  Yes      Disabled      Access
    1/3        FE        Enabled     Down       Enabled  Yes      Disabled      Access
    1/4        FE        Enabled     Down       N/A      Yes      Disabled      Access
    1/5        FE        Enabled     Down       N/A      Yes      Disabled      Access
    1/6        FE        Enabled     Up         N/A      Yes      Forwarding    Access
    1/7        FE        Enabled     Down       N/A      Yes      Disabled      Access
    1/8        GE        Enabled     Down       N/A      Yes      Disabled      Access
    lease 172.16.0.1 {
      starts epoch 1401422322; # Fri May 30 08:58:42 2014
      ends epoch 1401422938; # Fri May 30 09:08:58 2014
      cltt epoch 1401422322; # Fri May 30 08:58:42 2014
    DHCP Pools
               0
    Test          v4    Yes     0                  -              -            -
    Current leases          253
    Total leases            256
    DHCP enabled
    # default-pool
            max-lease-time 616;
            authoritative;
    (Aruba620) #show user
    Users
    IP MAC Name Role Age(d:h:m) Auth VPN link AP name Roa
    ming Essid/Bssid/Phy Profile Forward mode Type Host Name
    User Entries: 0/0
    Curr/**bleep** Alloc:0/0 Free:0/0 Dyn:0 AllocErr:0 FreeErr:0
    But my system now properly getting ip address from DHCP service.
  • 8.  RE: Controller 620 is not providing the DHCP service !!!
    Posted May 31, 2014 07:10 AM
    What port are you plugging your PC into?  I notice you have spanning-tree enabled, do you need to?   If not, run:
    no spanning-tree
    wr mem
  • 9.  RE: Controller 620 is not providing the DHCP service !!!
    Posted May 31, 2014 08:54 AM
    I want to set the lease time to 9hours.
    I test my laptop by connecting it at different ports i.e port 0 1 2 3 4 5 6 7 but after 10mins the dhcp lease would not be renew at each port.
    You said, DHCP lease must be renew after 10mins but after 10mins my laptop take link local address (169.224.0.0/16). I also apply this command on cmd ipconfig/renew but still not get new ip parameters. I have disabled my LAN card for a while then enable it but it couldnt get the NEW IP parameters from DHCP service.
     I am not sure about spanning tree whether it is enabled on each port or not !!!
  • 10.  RE: Controller 620 is not providing the DHCP service !!!
    Posted May 31, 2014 09:17 AM
    What version of ArubaOS are you running on the 620?
    If you want the lease time to be 9 hours, then issue the following:
    ip dhcp pool default-pool
    lease 0 9 0 0
    wr mem
    If you have a lease time of 9 hours, your client will usually attempt a renewal after 1/2 of the lease time has expired (in your case around 4.5 hours).   If it fails to renew, it will continue periodically.
    Spanning tree is enable by default.   Please try and disable it gloablly if you don't need it.
    no spanning-tree
    When a user is connected with an IP successfully, can you run show user to see if any users are in the table?   If the ports are trusted, you should not see them.
    show user
  • 11.  RE: Controller 620 is not providing the DHCP service !!!
    Posted May 31, 2014 10:04 AM
    AOS version 6.3.1.6
    Each port is trusted. When i run the command show user or show user-table it didnt show even a single entity.
    Note: Today is my holiday and i have no access of the controller, but the above commands show user or show user-table i have test yesterday, with port trusted condition.
    I will update here on monday 2nd june.
  • 12.  RE: Controller 620 is not providing the DHCP service !!!
    Posted Jun 03, 2014 12:02 AM
    I have do the following configuration.
    (Aruba620) (config) #ip dhcp pool default-pool
    (Aruba620) (config-dhcp)#lease 0 9 0 0
    (Aruba620) (config-dhcp)#write memory
    Saving Configuration...
    Configuration Saved.
    (Aruba620) (config-dhcp)#copy running-config startup-config
    DHCP enabled
    # default-pool
    default-lease-time 32400;
    max-lease-time 32400;
    authoritative;
    DHCP Pools
    default-pool v4 Yes 253 0 253 0
    0
    Test v4 Yes 0 - - -
    Current leases 253
    Total leases 256
    nterface
    But when i enter the command
    It didnt show any entity.
    I have done everthing from my end but still i am facing this issue.
  • 13.  RE: Controller 620 is not providing the DHCP service !!!
    Posted Jun 04, 2014 04:23 PM
    couple of things to try.
    - turn off spanning-tree (no spanning-tree command)
    - enable DHCP debugging
    config t
    logging level debug network subcat dhcp
    Try to get IP/renew/whatever
    share output of the following:
    show log network all | include <mac of client>
  • 14.  RE: Controller 620 is not providing the DHCP service !!!
    Posted Jun 09, 2014 12:37 AM
    There is no effect before and after disabling the Spanning tree by the command below.
    "no spanning stree"
    also apply the command
    lease 0 9 0 0
    wr mem
    But still controller didnt provide the dhcp service to the user. Show user command didnt show any user.
    On controller uplink port i am getting the DHCP before and after disabling STP. but on port 0 - 7 i am not getting DHCP service..
  • 15.  RE: Controller 620 is not providing the DHCP service !!!
    Posted Jun 09, 2014 08:06 AM
    Have you tried my suggestion of DHCP debugging:
    config t
    Try to get IP/renew/whatever is having a problem.
  • 16.  RE: Controller 620 is not providing the DHCP service !!!
    Posted Jun 09, 2014 08:13 AM
    Here is the output after applying the command in the config mode
    write mem....
    (Aruba620) #
    (Aruba620) #show log network all
    Jun 9 12:08:07 :202541: <DBUG> |dhcpdwrap| |dhcp| Received DHCP packet from Datpath, sos msg hdr flags 0x42 opcode 0x5a ingress 0x2128 vlan 1 egress 0x1 src mac a4:5d:36:c9:3f:e7
    Jun 9 12:08:07 :202534: <DBUG> |dhcpdwrap| |dhcp| Datapath vlan1: DISCOVER a4:5d:36:c9:3f:e7 Transaction ID:0x3aa3379a Options 3d:01a45d36c93fe7 0c:4944383931 3c:4d53465420352e30 37:010f03062c2e2f1f2179f92b
    Jun 9 12:08:07 :202523: <DBUG> |dhcpdwrap| |dhcp| dhcprelay: dev=eth1, length=300, from_port=68, op=1, giaddr=0.0.0.0
    Jun 9 12:08:07 :202532: <DBUG> |dhcpdwrap| |dhcp| got 0 relay servers
    Jun 9 12:08:08 :202541: <DBUG> |dhcpdwrap| |dhcp| Received DHCP packet from Datpath, sos msg hdr flags 0x42 opcode 0x5a ingress 0x0 vlan 1 egress 0x1 src mac 00:0b:86:63:c2:d0
    Jun 9 12:08:08 :202546: <DBUG> |dhcpdwrap| |dhcp| Datapath vlan1: OFFER a4:5d:36:c9:3f:e7 Transaction ID:0x3aa3379a clientIP=172.16.0.1
    Jun 9 12:08:08 :202523: <DBUG> |dhcpdwrap| |dhcp| dhcprelay: dev=eth1, length=318, from_port=68, op=1, giaddr=0.0.0.0
    Jun 9 12:08:08 :202532: <DBUG> |dhcpdwrap| |dhcp| got 0 relay servers
    Jun 9 12:08:08 :202541: <DBUG> |dhcpdwrap| |dhcp| Received DHCP packet from Datpath, sos msg hdr flags 0x42 opcode 0x5a ingress 0x2128 vlan 1 egress 0x1 src mac a4:5d:36:c9:3f:e7
    Jun 9 12:08:08 :202536: <DBUG> |dhcpdwrap| |dhcp| Datapath vlan1: REQUEST a4:5d:36:c9:3f:e7 Transaction ID:0x3aa3379a reqIP=172.16.0.1 Options 3d:01a45d36c93fe7 36:ac1000fe 0c:4944383931 51:00000049443839312e6d616b6b6179732e636f6d 3c:4d53465420352e30 37:010f03062c2e2f1f2179f92b
    Jun 9 12:08:08 :202544: <DBUG> |dhcpdwrap| |dhcp| Datapath vlan1: ACK a4:5d:36:c9:3f:e7 Transaction ID:0x3aa3379a clientIP=172.16.0.1
    Jun 9 12:08:11 :202541: <DBUG> |dhcpdwrap| |dhcp| Received DHCP packet from Datpath, sos msg hdr flags 0x42 opcode 0x5a ingress 0x2128 vlan 1 egress 0x1 src mac a4:5d:36:c9:3f:e7
    Jun 9 12:08:11 :202542: <DBUG> |dhcpdwrap| |dhcp| Datapath vlan1: INFORM a4:5d:36:c9:3f:e7 Transaction ID:0x1a84625c clientIP=172.16.0.1
    Jun 9 12:08:11 :202523: <DBUG> |dhcpdwrap| |dhcp| dhcprelay: dev=eth1, length=300, from_port=68, op=1, giaddr=0.0.0.0
    Jun 9 12:08:11 :202513: <DBUG> |dhcpdwrap| |dhcp| Could not find interface and/or vlan for ip=172.16.0.1, could be reply to mobility message.
    Jun 9 12:08:11 :202532: <DBUG> |dhcpdwrap| |dhcp| got 0 relay servers
    Jun 9 12:08:11 :202541: <DBUG> |dhcpdwrap| |dhcp| Received DHCP packet from Datpath, sos msg hdr flags 0x42 opcode 0x5a ingress 0x0 vlan 1 egress 0x2128 src mac 00:0b:86:63:c2:d0
    Jun 9 12:08:11 :202544: <DBUG> |dhcpdwrap| |dhcp| Datapath vlan1: ACK a4:5d:36:c9:3f:e7 Transaction ID:0x1a84625c clientIP=172.16.0.1
    Jun 9 12:08:16 :209801: <WARN> |fpapps| Physical link down: port 1/8
    Jun 9 12:08:48 :202541: <DBUG> |dhcpdwrap| |dhcp| Received DHCP packet from Datpath, sos msg hdr flags 0x42 opcode 0x5a ingress 0x2125 vlan 1 egress 0x1 src mac a4:5d:36:c9:3f:e7
    Jun 9 12:08:48 :202536: <DBUG> |dhcpdwrap| |dhcp| Datapath vlan1: REQUEST a4:5d:36:c9:3f:e7 Transaction ID:0x575c8b1f reqIP=172.16.0.1 Options 3d:01a45d36c93fe7 0c:4944383931 51:00000049443839312e6d616b6b6179732e636f6d 3c:4d53465420352e30 37:010f03062c2e2f1f2179f92b
    Jun 9 12:08:48 :202523: <DBUG> |dhcpdwrap| |dhcp| dhcprelay: dev=eth1, length=312, from_port=68, op=1, giaddr=0.0.0.0
    Jun 9 12:08:48 :202532: <DBUG> |dhcpdwrap| |dhcp| got 0 relay servers
    Jun 9 12:08:48 :202541: <DBUG> |dhcpdwrap| |dhcp| Received DHCP packet from Datpath, sos msg hdr flags 0x42 opcode 0x5a ingress 0x0 vlan 1 egress 0x2125 src mac 00:0b:86:63:c2:d0
    Jun 9 12:08:48 :202544: <DBUG> |dhcpdwrap| |dhcp| Datapath vlan1: ACK a4:5d:36:c9:3f:e7 Transaction ID:0x575c8b1f clientIP=172.16.0.1
    Jun 9 12:08:52 :202541: <DBUG> |dhcpdwrap| |dhcp| Received DHCP packet from Datpath, sos msg hdr flags 0x42 opcode 0x5a ingress 0x2125 vlan 1 egress 0x1 src mac a4:5d:36:c9:3f:e7
    Jun 9 12:08:52 :202542: <DBUG> |dhcpdwrap| |dhcp| Datapath vlan1: INFORM a4:5d:36:c9:3f:e7 Transaction ID:0x9deb3342 clientIP=172.16.0.1
    Jun 9 12:08:52 :202523: <DBUG> |dhcpdwrap| |dhcp| dhcprelay: dev=eth1, length=300, from_port=68, op=1, giaddr=0.0.0.0
    Jun 9 12:08:52 :202513: <DBUG> |dhcpdwrap| |dhcp| Could not find interface and/or vlan for ip=172.16.0.1, could be reply to mobility message.
    Jun 9 12:08:52 :202532: <DBUG> |dhcpdwrap| |dhcp| got 0 relay servers
    Jun 9 12:08:52 :202541: <DBUG> |dhcpdwrap| |dhcp| Received DHCP packet from Datpath, sos msg hdr flags 0x42 opcode 0x5a ingress 0x0 vlan 1 egress 0x2125 src mac 00:0b:86:63:c2:d0
    Jun 9 12:08:52 :202544: <DBUG> |dhcpdwrap| |dhcp| Datapath vlan1: ACK a4:5d:36:c9:3f:e7 Transaction ID:0x9deb3342 clientIP=172.16.0.1
    Jun 9 12:09:05 :209801: <WARN> |fpapps| Physical link down: port 1/5
    Jun 9 12:09:41 :202541: <DBUG> |dhcpdwrap| |dhcp| Received DHCP packet from Datpath, sos msg hdr flags 0x42 opcode 0x5a ingress 0x2125 vlan 1 egress 0x1 src mac a4:5d:36:c9:3f:e7
    Jun 9 12:09:41 :202536: <DBUG> |dhcpdwrap| |dhcp| Datapath vlan1: REQUEST a4:5d:36:c9:3f:e7 Transaction ID:0xea6b48a1 reqIP=172.16.0.1 Options 3d:01a45d36c93fe7 0c:4944383931 51:00000049443839312e6d616b6b6179732e636f6d 3c:4d53465420352e30 37:010f03062c2e2f1f2179f92b
    Jun 9 12:09:41 :202523: <DBUG> |dhcpdwrap| |dhcp| dhcprelay: dev=eth1, length=312, from_port=68, op=1, giaddr=0.0.0.0
    Jun 9 12:09:41 :202532: <DBUG> |dhcpdwrap| |dhcp| got 0 relay servers
    Jun 9 12:09:41 :202541: <DBUG> |dhcpdwrap| |dhcp| Received DHCP packet from Datpath, sos msg hdr flags 0x42 opcode 0x5a ingress 0x0 vlan 1 egress 0x1 src mac 00:0b:86:63:c2:d0
    Jun 9 12:09:41 :202544: <DBUG> |dhcpdwrap| |dhcp| Datapath vlan1: ACK a4:5d:36:c9:3f:e7 Transaction ID:0xea6b48a1 clientIP=172.16.0.1
    Jun 9 12:09:45 :209801: <WARN> |fpapps| Physical link down: port 1/5
  • 17.  RE: Controller 620 is not providing the DHCP service !!!
    Posted Jun 09, 2014 08:22 AM
  • 18.  RE: Controller 620 is not providing the DHCP service !!!
    Posted Jun 09, 2014 08:23 AM
    I have applied the command. here is the output
    What is the purpose of this command  ??
  • 19.  RE: Controller 620 is not providing the DHCP service !!!
    Posted Jun 09, 2014 08:24 AM
    Here is the ouptut.
  • 20.  RE: Controller 620 is not providing the DHCP service !!!
    Posted Jun 09, 2014 08:32 AM
    Here is the output .
    Jun 9 12:25:32 :202515: <DBUG> |dhcpdwrap| |dhcp| In relayScan
    Jun 9 12:25:32 :202518: <DBUG> |dhcpdwrap| |dhcp| relayScan added descriptor 18 to Dispatcher, return=268664424
    Jun 9 12:25:32 :202518: <DBUG> |dhcpdwrap| |dhcp| relayScan added descriptor 17 to Dispatcher, return=268664512
    Jun 9 12:25:32 :202521: <DBUG> |dhcpdwrap| |dhcp| relayScan done
    Jun 9 12:25:32 :202514: <DBUG> |dhcpdwrap| |dhcp| done with relayInit
    Jun 9 12:26:37 :209801: <WARN> |fpapps| Physical link down: port 1/4
    Jun 9 12:27:17 :202523: <DBUG> |dhcpdwrap| |dhcp| dhcprelay: dev=eth1, length=300, from_port=68, op=1, giaddr=0.0.0.0
    Jun 9 12:27:17 :202532: <DBUG> |dhcpdwrap| |dhcp| got 0 relay servers
    Jun 9 12:27:18 :202541: <DBUG> |dhcpdwrap| |dhcp| Received DHCP packet from Datpath, sos msg hdr flags 0x42 opcode 0x5a ingress 0x0 vlan 1 egress 0x1 src mac 00:0b:86:63:c2:d0
    Jun 9 12:27:18 :202546: <DBUG> |dhcpdwrap| |dhcp| Datapath vlan1: OFFER a4:5d:36:c9:3f:e7 Transaction ID:0xb3706048 clientIP=172.16.0.1
    Jun 9 12:27:18 :202541: <DBUG> |dhcpdwrap| |dhcp| Received DHCP packet from Datpath, sos msg hdr flags 0x42 opcode 0x5a ingress 0x2124 vlan 1 egress 0x1 src mac a4:5d:36:c9:3f:e7
    Jun 9 12:27:18 :202536: <DBUG> |dhcpdwrap| |dhcp| Datapath vlan1: REQUEST a4:5d:36:c9:3f:e7 Transaction ID:0xb3706048 reqIP=172.16.0.1 Options 3d:01a45d36c93fe7 36:ac1000fe 0c:4944383931 51:00000049443839312e6d616b6b6179732e636f6d 3c:4d53465420352e30 37:010f03062c2e2f1f2179f92b
    Jun 9 12:27:18 :202523: <DBUG> |dhcpdwrap| |dhcp| dhcprelay: dev=eth1, length=318, from_port=68, op=1, giaddr=0.0.0.0
    Jun 9 12:27:18 :202532: <DBUG> |dhcpdwrap| |dhcp| got 0 relay servers
    Jun 9 12:27:18 :202544: <DBUG> |dhcpdwrap| |dhcp| Datapath vlan1: ACK a4:5d:36:c9:3f:e7 Transaction ID:0xb3706048 clientIP=172.16.0.1
    Jun 9 12:27:21 :202541: <DBUG> |dhcpdwrap| |dhcp| Received DHCP packet from Datpath, sos msg hdr flags 0x42 opcode 0x5a ingress 0x2124 vlan 1 egress 0x1 src mac a4:5d:36:c9:3f:e7
    Jun 9 12:27:21 :202542: <DBUG> |dhcpdwrap| |dhcp| Datapath vlan1: INFORM a4:5d:36:c9:3f:e7 Transaction ID:0xff9a73c6 clientIP=172.16.0.1
    Jun 9 12:27:21 :202523: <DBUG> |dhcpdwrap| |dhcp| dhcprelay: dev=eth1, length=300, from_port=68, op=1, giaddr=0.0.0.0
    Jun 9 12:27:21 :202513: <DBUG> |dhcpdwrap| |dhcp| Could not find interface and/or vlan for ip=172.16.0.1, could be reply to mobility message.
    Jun 9 12:27:21 :202532: <DBUG> |dhcpdwrap| |dhcp| got 0 relay servers
    Jun 9 12:27:21 :202541: <DBUG> |dhcpdwrap| |dhcp| Received DHCP packet from Datpath, sos msg hdr flags 0x42 opcode 0x5a ingress 0x0 vlan 1 egress 0x2124 src mac 00:0b:86:63:c2:d0
    Jun 9 12:27:21 :202544: <DBUG> |dhcpdwrap| |dhcp| Datapath vlan1: ACK a4:5d:36:c9:3f:e7 Transaction ID:0xff9a73c6 clientIP=172.16.0.1
  • 21.  RE: Controller 620 is not providing the DHCP service !!!
    Posted Jun 09, 2014 08:43 AM
    After the debug command... Now i am getting the DHCP service on each port of  controller with a lease time 23 hours.
    But i have to check whether the lease time would automatically change or not ?
    However i also applied copy run startup config and write mem....
    After testing on each port i will update you soon..
    But what is the purpose of this command ?
    logging level debug network subcat dhcp. Please explain me .
  • 22.  RE: Controller 620 is not providing the DHCP service !!!
    Posted Jun 09, 2014 10:21 AM
    The debugging command is only to enable a higher of logging (so we could troubleshoot the logs).  It has not technical implications.  Keep checking the clients and reviewing the the network log if you have a renewal problem.
    Also, you should disable it when you are done troubleshooting:
    no logging level debug network subcat dhcp
  • 23.  RE: Controller 620 is not providing the DHCP service !!!
    Posted Jun 09, 2014 11:41 PM
    Now the ip address automatically renew when the lease time expires. Also disable the no logging level debug network subcat dhcp.
    Now it getting the IP address from DHCP service on each port. My question is what was the problem ?
    I have restart the controller, client machine gets the ip from DHCP service. lease time set to 1 hour. Controller is not connected to any part of the network. So i didnt set the Default gateway on controller.
    Here is the output.
    lease 172.16.0.1 {
    starts epoch 1402376072; # Tue Jun 10 09:54:32 2014
    ends epoch 1402379672; # Tue Jun 10 10:54:32 2014
    cltt epoch 1402376072; # Tue Jun 10 09:54:32 2014
    DHCP Pools
    Network Name Type Active Configured leases Active leases Free leases Expired leases Abandoned leases
    Default v4 Yes 253 1 252 0 0
    Current leases 253
    Total leases 256
    DHCP enabled
    # Default
    default-lease-time 3600;
    max-lease-time 3600;
    option vendor-class-identifier "ArubaAP";
    option vendor-encapsulated-options "172.16.0.254";
    authoritative;
  • 24.  RE: Controller 620 is not providing the DHCP service !!!
    Posted Jun 10, 2014 01:26 AM
    FYI:
    the command u disabled it's only logging command < > try to find your DHCP issue in other part (it dosent sound like it solved)
  • 25.  RE: Controller 620 is not providing the DHCP service !!!
    Posted Jun 10, 2014 11:50 PM
    According to your above post, yes you are right, this command cannot have any technical implication. But after applying this command my issue is resolved.
    STRANGE BUT TRUE !!!!
  • 26.  RE: Controller 620 is not providing the DHCP service !!!
    Posted May 30, 2014 01:40 AM
    Still having a Problem on DHCP service...
    I have select the DHCP service lease time 0days, 0hours, 0mins and 0secs apply done and save configuration.
    After 10 mins i have checked that lease time again set to 10mins and 60secs.
    Agains dhcp service problem
    lease 172.16.0.1 {
    starts epoch 1401427674; # Fri May 30 10:27:54 2014
    ends epoch 1401428290; # Fri May 30 10:38:10 2014
    cltt epoch 1401427674; # Fri May 30 10:27:54 2014
  • 27.  RE: Controller 620 is not providing the DHCP service !!!
    Posted May 30, 2014 07:37 AM
    you cannot set the lease time to 0 days, 0 hours, 0 minutes (15 seconds is the minimum I believe).   Please set it to something like 4 hours to test.   Regardless, even if it is 10 minutes, the client should renew its IP without issue.
  • 28.  RE: Controller 620 is not providing the DHCP service !!!
    Posted May 30, 2014 10:33 AM
    I have again set the lease time to 0days 23hours 60mins and 60sec  but after sometime when i check it revert back to 10mins and 60secs.. although i have aply and configuration and then save configuration.
    However i am not the new user on aruba controller platoform. I knew about it but facing such type of problem first time.
  • 29.  RE: Controller 620 is not providing the DHCP service !!!
    Posted May 31, 2014 07:07 AM
    Can you confirm what you believe your lease times to be?  You should not be able to set 60mins or 60sec; 0-59 should be the valid values.  Please run the following on your setup:
    lease 0 1 0 0
    wr mem
    This shoudl set the lease at 1 hour.
    Verify the default-lease-time and max-lease-time read 3600
  • 30.  RE: Controller 620 is not providing the DHCP service !!!
    Posted May 30, 2014 01:07 PM
    after 10mins client didnt get renew IP parameters :(
