  • 1.  Controller 7005 can use switching mode
    Posted May 13, 2022 03:27 AM
    Hi, I'm phoom
    I have a question. I have 2 uplink  VLAN1 : 172.16.1.0/24 , VLAN2 : 172.16.2.0/24 vlan management is 1. both vlan get dhcp from server when I plugin cable to switch VLAN1 can ping gateway of vlan1 but VLAN2 can't ping to gateway vlan2
    topology in this belw
    Thanks.
    Nattaphoom Kangsri
  • 2.  RE: Controller 7005 can use switching mode
    Posted May 13, 2022 09:07 AM
    Is the WLC connected to the switch with two separate physical connections, or is it a trunk?  Type "show port status" on the WLC to make sure both interfaces are up and not disabled by spanning tree.
  • 3.  RE: Controller 7005 can use switching mode
    Posted May 17, 2022 10:27 PM
    Hi cjoseoh
    i have 2 switch CoreSwitch and Hubswitch  uplink to core is trunk mode and uplink to HubSwitch is access mode i will try your recommend
    Thank you
    Nattaphoom Kangsri
