last person joined: 11 hours ago
Controller 7005 - issues with inter-vlan routing
  • 1.  Controller 7005 - issues with inter-vlan routing
    Posted Sep 06, 2018 01:24 PM
    My issue is that I am unable to ping from one vlan to another on the 7005 controller.
    Its been many years since i've configured an Aruba controller so I'm sure my issue is due to me overlooking something.  We recieved this small controller for testing in the lab with the ultimate goal of testing the IPSec tunnel functionality.
    Aruba Controller 7005-US JW634A
    ArubaOS 6.5.1.4 build 58698
    I have set up the following:
    LAN: Vlan 1 - 10.57.30.32/29 - 10.57.30.33 - Ports 0 - 2
    WAN: Vlan 10 - 192.168.0.0/24 - 192.168.0.117 - Port 3
    Inter-vlan routing has been configured for both vlans.
    DHCP is configured for the LAN and does work.
    My laptop pulls 10.57.30.35 on Port 1 and I can ping 10.57.30.33.  However, I cannot ping 192.168.0.117.
    The controller is plugged into another device and I can ping from vlan 10 to 192.168.0.1.  I cannot ping from 10.57.30.33 to 192.168.0.1.
    Thanks in advance for suggestions.
    Here is the config.  Sorry for posting the whole thing but I'm not sure where the issue is:
    (Aruba7005) (config) #show run
    Building Configuration...
    version 6.5
    enable secret "******"
    enable bypass
    loginsession timeout 0
    hostname "Aruba7005"
    clock timezone PST -8
    location "Building1.floor1"
    controller config 3
    ip NAT pool dynamic-srcnat 0.0.0.0 0.0.0.0
    ip access-list geolocation global-geolocation-acl
    ip access-list eth validuserethacl
      permit any
    netservice svc-ipp-tcp tcp 631
    netservice svc-dhcp udp 67 68 alg dhcp
    netservice svc-citrix tcp 2598
    netservice svc-pcoip-udp udp 50002
    netservice svc-netbios-ssn tcp 139
    netservice svc-tftp udp 69 alg tftp
    netservice svc-papi udp 8211
    netservice svc-ica tcp 1494
    netservice svc-natt udp 4500
    netservice svc-lpd tcp 515
    netservice svc-microsoft-ds tcp 445
    netservice svc-syslog udp 514
    netservice svc-msrpc-tcp tcp 135 139
    netservice svc-msrpc-udp udp 135 139
    netservice svc-smtp tcp 25
    netservice svc-http-proxy2 tcp 8080
    netservice svc-cfgm-tcp tcp 8211
    netservice vnc tcp 5900 5905
    netservice svc-web tcp list "80 443"
    netservice svc-h323-udp udp 1718 1719
    netservice svc-sccp tcp 2000 alg sccp
    netservice svc-bootp udp 67 69
    netservice svc-telnet tcp 23
    netservice svc-http tcp 80
    netservice svc-vmware-rdp tcp 3389
    netservice svc-ipp-udp udp 631
    netservice svc-noe-oxo udp 5000 alg noe
    netservice svc-vocera udp 5002 alg vocera
    netservice svc-esp 50
    netservice svc-http-proxy1 tcp 3128
    netservice svc-sec-papi udp 8209
    netservice svc-l2tp udp 1701
    netservice svc-rtsp tcp 554 alg rtsp
    netservice svc-gre 47
    netservice svc-sip-tcp tcp 5060
    netservice svc-pptp tcp 1723
    netservice svc-snmp udp 161
    netservice svc-svp 119 alg svp
    netservice svc-icmp 1
    netservice svc-smb-tcp tcp 445
    netservice svc-pcoip2-tcp tcp 4172
    netservice svc-v6-icmp 58
    netservice svc-ssh tcp 22
    netservice svc-h323-tcp tcp 1720
    netservice svc-ntp udp 123
    netservice svc-pop3 tcp 110
    netservice svc-netbios-ns udp 137
    netservice svc-adp udp 8200
    netservice svc-v6-dhcp udp 546 547
    netservice svc-dns udp 53 alg dns
    netservice svc-netbios-dgm udp 138
    netservice svc-http-proxy3 tcp 8888
    netservice svc-sip-udp udp 5060
    netservice svc-kerberos udp 88
    netservice svc-sips tcp 5061 alg sips
    netservice svc-pcoip2-udp udp 4172
    netservice svc-pcoip-tcp tcp 50002
    netservice svc-noe udp 32512 alg noe
    netservice svc-nterm tcp 1026 1028
    netservice svc-ike udp 500
    netservice svc-snmp-trap udp 162
    netservice svc-smb-udp udp 445
    netservice svc-ftp tcp 21 alg ftp
    netservice svc-https tcp 443
    netexthdr default
    time-range working-hours periodic
     weekday 08:00 to  18:00
    time-range night-hours periodic
     weekday 18:01 to  23:59
     weekday 00:00 to  07:59
    time-range weekend periodic
     weekend 00:00 to  23:59
    ip access-list session svp-acl
    ip access-list session apprf-stateful-dot1x-sacl
    ip access-list session logon-control
    ip access-list session ap-uplink-acl
    ip access-list session v6-http-acl
    ip access-list session v6-logon-control
    ip access-list session http-acl
    ip access-list session icmp-acl
    ip access-list session vocera-acl
    ip access-list session vmware-acl
    ip access-list session citrix-acl
    ip access-list session tftp-acl
    ip access-list session sip-acl
    ip access-list session ra-guard
    ip access-list session srcnat
    ip access-list session global-sacl
    ip access-list session v6-dhcp-acl
    ip access-list session cplogout
    ip access-list session wificalling-acl
    ip access-list session vpnlogon
    ip access-list session v6-control
    ip access-list session allow-diskservices
    ip access-list session apprf-guest-sacl
    ip access-list session wificalling-block
    ip access-list session v6-ap-acl
    ip access-list session v6-allowall
    ip access-list session v6-icmp-acl
    ip access-list session validuser
      network 127.0.0.0 255.0.0.0 any any  deny
      network 169.254.0.0 255.255.0.0 any any  deny
      network 224.0.0.0 240.0.0.0 any any  deny
      host 255.255.255.255 any any  deny
      network 240.0.0.0 240.0.0.0 any any  deny
      any any any  permit
      ipv6 host fe80:: any any  deny
      ipv6 network fc00::/7 any any  permit
      ipv6 network fe80::/64 any any  permit
      ipv6  alias ipv6-reserved-range any any  deny
      ipv6  any any any  permit
    ip access-list session v6-dns-acl
    ip access-list session captiveportal
    ip access-list session v6-https-acl
    ip access-list session dhcp-acl
    ip access-list session h323-acl
    ip access-list session allowall
    ip access-list session allow-printservices
    ip access-list session https-acl
    ip access-list session skinny-acl
    ip access-list session ap-acl
    ip access-list session captiveportal6
    ip access-list session control
    ip access-list session dns-acl
    ip access-list session noe-acl
    vpn-dialer default-dialer
      ike authentication PRE-SHARE ******
    user-role ap-role
    user-role sys-ap-role
    user-role stateful-dot1x
    user-role guest-logon
    user-role logon
    user-role cpbase
    user-role denyall
    user-role guest
    user-role default-iap-user-role
    kernel coredump
    interface mgmt
            shutdown
    dialer group evdo_us
      init-string ATQ0V1E0
      dial-string ATDT#777
    dialer group gsm_us
      init-string AT+CGDCONT=1,"IP","ISP.CINGULAR"
      dial-string ATD*99#
    dialer group gsm_asia
      init-string AT+CGDCONT=1,"IP","internet"
      dial-string ATD*99***1#
    dialer group vivo_br
      init-string AT+CGDCONT=1,"IP","zap.vivo.com.br"
      dial-string ATD*99#
    vlan 10 "WAN"
    interface gigabitethernet 0/0/0
            description "GE0/0/0"
            trusted
            trusted vlan 1-4094
    interface gigabitethernet 0/0/1
            description "GE0/0/1"
            trusted
            trusted vlan 1-4094
    interface gigabitethernet 0/0/2
            description "GE0/0/2"
            trusted
            trusted vlan 1-4094
    interface gigabitethernet 0/0/3
            description "GE0/0/3"
            trusted
            trusted vlan 1-4094
            switchport access vlan 10
    interface vlan 1
            ip address 10.57.30.33 255.255.255.248
    interface vlan 10
            ip address 192.168.0.117 255.255.255.0
            description "WAN to CRADLEPOINT"
    ip default-gateway 192.168.0.1
    no uplink wired vlan 1
    uplink disable
    ip nexthop-list pan-gp-ipsec-map-list
    crypto isakmp policy 20
      encryption aes256
    crypto isakmp policy 10001
    crypto isakmp policy 10002
      encryption aes256
      authentication rsa-sig
    crypto isakmp policy 10003
      encryption aes256
    crypto isakmp policy 10004
      version v2
      encryption aes256
    crypto isakmp policy 10005
      encryption aes256
    crypto isakmp policy 10006
      version v2
      encryption aes128
    crypto isakmp policy 10007
      version v2
      encryption aes128
    crypto isakmp policy 10008
      version v2
      encryption aes128
      hash sha2-256-128
      group 19
      authentication ecdsa-256
      prf prf-hmac-sha256
    crypto isakmp policy 10009
      version v2
      encryption aes256
      hash sha2-384-192
      group 20
      authentication ecdsa-384
      prf prf-hmac-sha384
    crypto isakmp policy 10012
      version v2
      encryption aes256
    crypto isakmp policy 10013
      encryption aes256
    crypto ipsec transform-set default-ha-transform esp-3des esp-sha-hmac
    crypto ipsec transform-set default-boc-bm-transform esp-aes256 esp-sha-hmac
    crypto ipsec transform-set default-1st-ikev2-transform esp-aes256 esp-sha-hmac
    crypto ipsec transform-set default-3rd-ikev2-transform esp-aes128 esp-sha-hmac
    crypto ipsec transform-set default-rap-transform esp-aes256 esp-sha-hmac
    crypto ipsec transform-set default-aes esp-aes256 esp-sha-hmac
    crypto dynamic-map default-rap-ipsecmap 10001
      version v2
      set transform-set "default-gcm256" "default-gcm128" "default-rap-transform"
    crypto dynamic-map default-dynamicmap 10000
      set transform-set "default-transform" "default-aes"
    crypto map GLOBAL-IKEV2-MAP 10000 ipsec-isakmp dynamic default-rap-ipsecmap
    crypto map GLOBAL-MAP 10000 ipsec-isakmp dynamic default-dynamicmap
    crypto isakmp eap-passthrough eap-tls
    crypto isakmp eap-passthrough eap-peap
    crypto isakmp eap-passthrough eap-mschapv2
    vpdn group l2tp
    ip dhcp excluded-address 10.57.30.32 10.57.30.34
    ip dhcp pool local_pool
     default-router 10.57.30.33
     dns-server 8.8.8.8
     lease 0 0 10 0
     network 10.57.30.32 255.255.255.248
     authoritative
    service dhcp
    vpdn group pptp
    tunneled-node-address 0.0.0.0
    ap-crash-transfer
    adp discovery enable
    adp igmp-join enable
    adp igmp-vlan 0
    ap ap-blacklist-time 3600
    ap flush-r1-on-new-r0 disable
    amon msg-buffer-size 32768
    stm mon-update-queue 7248
    no ssh mgmt-auth public-key
    ssh mgmt-auth username/password
    mgmt-user admin root 1e4db828018c2dcdfb6f87cbb471002ede6813243d35060cc9
    no database synchronize
    ip mobile domain default
    airgroup mdns "disable"
    airgroup dlna "disable"
    airgroup location-discovery "enable"
    airgroup active-wireless-discovery "disable"
    airgroupservice "airplay"
      id "_airplay._tcp"
      id "_raop._tcp"
      id "_appletv-v2._tcp"
      description "AirPlay"
    airgroupservice "airprint"
      id "_ipp._tcp"
      id "_pdl-datastream._tcp"
      id "_printer._tcp"
      id "_scanner._tcp"
      id "_http._tcp"
      id "_http-alt._tcp"
      id "_ipp-tls._tcp"
      id "_fax-ipp._tcp"
      id "_riousbprint._tcp"
      id "_ica-networking._tcp"
      id "_ptp._tcp"
      id "_canon-bjnp1._tcp"
      id "_ipps._tcp"
      id "_ica-networking2._tcp"
      description "AirPrint"
    airgroupservice "itunes"
      id "_home-sharing._tcp"
      id "_apple-mobdev._tcp"
      id "_daap._tcp"
      id "_dacp._tcp"
      description "iTunes"
    airgroupservice "remotemgmt"
      id "_ssh._tcp"
      id "_sftp-ssh._tcp"
      id "_ftp._tcp"
      id "_telnet._tcp"
      id "_rfb._tcp"
      id "_net-assistant._tcp"
      description "Remote management"
    airgroupservice "sharing"
      id "_odisk._tcp"
      id "_afpovertcp._tcp"
      id "_xgrid._tcp"
      description "Sharing"
    airgroupservice "chat"
      id "_presence._tcp"
      description "Chat"
    airgroupservice "googlecast"
      id "_googlecast._tcp"
      description "GoogleCast supported by Chromecast etc"
    airgroupservice "AmazonTV"
      id "_amzn-wplay._tcp"
      description "Amazon fire tv"
    airgroupservice "DIAL"
      id "urn:dial-multiscreen-org:service:dial:1"
      id "urn:dial-multiscreen-org:device:dial:1"
      description "DIAL supported by Chromecast, FireTV, Roku etc"
    airgroupservice "DLNA Media"
      id "urn:schemas-upnp-org:device:MediaServer:1"
      id "urn:schemas-upnp-org:device:MediaServer:2"
      id "urn:schemas-upnp-org:device:MediaServer:3"
      id "urn:schemas-upnp-org:device:MediaServer:4"
      id "urn:schemas-upnp-org:device:MediaRenderer:1"
      id "urn:schemas-upnp-org:device:MediaRenderer:2"
      id "urn:schemas-upnp-org:device:MediaRenderer:3"
      id "urn:schemas-upnp-org:device:MediaPlayer:1"
      description "Media"
    airgroupservice "DLNA Print"
      id "urn:schemas-upnp-org:device:Printer:1"
      id "urn:schemas-upnp-org:service:PrintBasic:1"
      id "urn:schemas-upnp-org:service:PrintEnhanced:1"
      description "Print"
    airgroupservice "allowall"
      description "Remaining-Services"
    airgroup service "airplay" enable
    airgroup service "airprint" enable
    airgroup service "itunes" disable
    airgroup service "remotemgmt" disable
    airgroup service "sharing" disable
    airgroup service "chat" disable
    airgroup service "googlecast" disable
    airgroup service "AmazonTV" disable
    airgroup service "DIAL" enable
    airgroup service "DLNA Media" disable
    airgroup service "DLNA Print" disable
    airgroup service "allowall" disable
    ip igmp
    ipv6 mld
    firewall attack-rate grat-arp 50 drop
    ipv6 firewall ext-hdr-parse-len  100
    firewall cp
    ip domain lookup
    country US
    aaa authentication mac "default"
    aaa authentication dot1x "default"
    aaa server-group "default"
     auth-server Internal
     set role condition role value-of
    aaa profile "default"
    aaa authentication captive-portal "default"
    aaa authentication wispr "default"
    aaa authentication vpn "default"
    aaa authentication vpn "default-rap"
    aaa authentication mgmt
    aaa authentication stateful-ntlm "default"
    aaa authentication stateful-kerberos "default"
    aaa authentication stateful-dot1x
    aaa authentication wired
    web-server profile
       session-timeout 3600
    guest-access-email
    aaa password-policy mgmt
    control-plane-security
    ids wms-general-profile
    ids wms-local-system-profile
    valid-network-oui-profile
    upgrade-profile
    license profile
    activate-service-whitelist
    file syncing profile
    papi-security
    ifmap cppm
    pan profile "default"
    pan-options
    pan active-profile
    openflow-profile
    aruba-central
    ap system-profile "default"
       ap-console-password c573264493818910e1b42fbdc9940b0f9629e808d804de19
    ap regulatory-domain-profile "default"
       country-code US
       valid-11g-channel 1
       valid-11g-channel 6
       valid-11g-channel 11
       valid-11a-channel 36
       valid-11a-channel 40
       valid-11a-channel 44
       valid-11a-channel 48
       valid-11a-channel 149
       valid-11a-channel 153
       valid-11a-channel 157
       valid-11a-channel 161
       valid-11a-channel 165
       valid-11g-40mhz-channel-pair 1-5
       valid-11g-40mhz-channel-pair 7-11
       valid-11a-40mhz-channel-pair 36-40
       valid-11a-40mhz-channel-pair 44-48
       valid-11a-40mhz-channel-pair 149-153
       valid-11a-40mhz-channel-pair 157-161
       valid-11a-80mhz-channel-group 36-48
       valid-11a-80mhz-channel-group 149-161
       valid-11a-160mhz-channel-group 36-64
    ap wired-ap-profile "default"
    ap enet-link-profile "default"
    ap mesh-ht-ssid-profile "default"
    ap lldp med-network-policy-profile "default"
    ap mesh-cluster-profile "default"
    ap lldp profile "default"
    ap mesh-radio-profile "default"
    ap wired-port-profile "default"
    ids general-profile "default"
    ids unauthorized-device-profile "default"
    ids profile "default"
    rf arm-profile "arm-maintain"
       assignment maintain
       no scanning
    rf arm-profile "arm-scan"
    rf optimization-profile "default"
    rf event-thresholds-profile "default"
    rf am-scan-profile "default"
    rf dot11a-radio-profile "default"
    rf dot11a-radio-profile "rp-maintain-a"
    rf dot11a-radio-profile "rp-monitor-a"
       mode am-mode
    rf dot11a-radio-profile "rp-scan-a"
    rf dot11g-radio-profile "default"
    rf dot11g-radio-profile "rp-maintain-g"
    rf dot11g-radio-profile "rp-monitor-g"
       mode am-mode
    rf dot11g-radio-profile "rp-scan-g"
    wlan handover-trigger-profile "default"
    wlan rrm-ie-profile "default"
    wlan bcn-rpt-req-profile "default"
    wlan dot11r-profile "default"
    wlan tsm-req-profile "default"
    wlan ht-ssid-profile "default"
    wlan hotspot anqp-venue-name-profile "default"
    wlan hotspot anqp-nwk-auth-profile "default"
    wlan hotspot anqp-roam-cons-profile "default"
    wlan hotspot anqp-nai-realm-profile "default"
    wlan hotspot anqp-3gpp-nwk-profile "default"
    wlan hotspot h2qp-operator-friendly-name-profile "default"
    wlan hotspot h2qp-wan-metrics-profile "default"
    wlan hotspot h2qp-conn-capability-profile "default"
    wlan hotspot h2qp-op-cl-profile "default"
    wlan hotspot h2qp-osu-prov-list-profile "default"
    wlan hotspot anqp-ip-addr-avail-profile "default"
    wlan hotspot anqp-domain-name-profile "default"
    wlan dot11k-profile "default"
    wlan ssid-profile "default"
    wlan hotspot advertisement-profile "default"
    wlan hotspot hs2-profile "default"
    wlan virtual-ap "default"
    ap provisioning-profile "default"
    rf arm-rf-domain-profile
       arm-rf-domain-key "0c318048f08f3e0cc5d054c161836ddb"
    ap-lacp-striping-ip
    ap general-profile
    ap-group "default"
    airgroup cppm-server aaa
    logging level warnings security subcat ids
    logging level warnings security subcat ids-ap
    snmp-server enable trap
    snmp-server trap source 0.0.0.0
    snmp-server trap disable  wlsxAdhocNetwork
    snmp-server trap disable  wlsxAdhocNetworkBridgeDetectedAP
    snmp-server trap disable  wlsxAdhocNetworkBridgeDetectedSta
    snmp-server trap disable  wlsxAdhocUsingValidSSID
    snmp-server trap disable  wlsxAuthMaxAclEntries
    snmp-server trap disable  wlsxAuthMaxBWContracts
    snmp-server trap disable  wlsxAuthMaxUserEntries
    snmp-server trap disable  wlsxAuthServerIsUp
    snmp-server trap disable  wlsxAuthServerReqTimedOut
    snmp-server trap disable  wlsxAuthServerTimedOut
    snmp-server trap disable  wlsxChannelChanged
    snmp-server trap disable  wlsxCoverageHoleDetected
    snmp-server trap disable  wlsxDBCommunicationFailure
    snmp-server trap disable  wlsxDisconnectStationAttack
    snmp-server trap disable  wlsxESIServerDown
    snmp-server trap disable  wlsxESIServerUp
    snmp-server trap disable  wlsxFanFailure
    snmp-server trap disable  wlsxFanTrayInserted
    snmp-server trap disable  wlsxFanTrayRemoved
    snmp-server trap disable  wlsxGBICInserted
    snmp-server trap disable  wlsxIpSpoofingDetected
    snmp-server trap disable  wlsxLCInserted
    snmp-server trap disable  wlsxLCRemoved
    snmp-server trap disable  wlsxLicenseExpiry
    snmp-server trap disable  wlsxLowMemory
    snmp-server trap disable  wlsxLowOnFlashSpace
    snmp-server trap disable  wlsxOutOfRangeTemperature
    snmp-server trap disable  wlsxOutOfRangeVoltage
    snmp-server trap disable  wlsxPowerSupplyFailure
    snmp-server trap disable  wlsxPowerSupplyMissing
    snmp-server trap disable  wlsxProcessDied
    snmp-server trap disable  wlsxProcessExceedsMemoryLimits
    snmp-server trap disable  wlsxSCInserted
    snmp-server trap disable  wlsxSignatureMatch
    snmp-server trap disable  wlsxStaUnAssociatedFromUnsecureAP
    snmp-server trap disable  wlsxStationAddedToBlackList
    snmp-server trap disable  wlsxStationRemovedFromBlackList
    snmp-server trap disable  wlsxSwitchIPChanged
    snmp-server trap disable  wlsxSwitchRoleChange
    snmp-server trap disable  wlsxUserAuthenticationFailed
    snmp-server trap disable  wlsxUserEntryAuthenticated
    snmp-server trap disable  wlsxUserEntryChanged
    snmp-server trap disable  wlsxUserEntryCreated
    snmp-server trap disable  wlsxUserEntryDeAuthenticated
    snmp-server trap disable  wlsxUserEntryDeleted
    snmp-server trap disable  wlsxVrrpStateChange
    process monitor log
    ip probe default
      mode Ping
      frequency 10
      retries 3
      burst-size 5
    ip probe health-check
      mode Ping
      frequency 10
      retries 3
      burst-size 5
    activate periodic-sync enable
    end
  • 2.  RE: Controller 7005 - issues with inter-vlan routing
    Posted Sep 06, 2018 01:49 PM
    What does the routing table look like on the CradlePoint device at 192.168.0.1? It should have a static route for your 10.57.30.32/29 subnet pointing to 192.168.0.117.
    Likewise, verify the laptop configuration is pointing to 10.57.30.33 as it's default gateway, and that no VPN clients are connected or otherwise modifying the routing table.
  • 3.  RE: Controller 7005 - issues with inter-vlan routing
    Posted Sep 06, 2018 02:39 PM
    Unfortunately, the cradlepoint is our customers device and we dont have access into it.  Its one of the reasons this has been such a hassle to troubleshoot.  The 10.57.30.32/29 block, ultimately, wont be routed through the cradlepoint as it will be behind an IPSec tunnel.  If the 7005 config looks ok, then I'll inform the customer we cannot move forward.
    I did do the following:
    (Aruba7005) #show ip route
    Codes: C - connected, O - OSPF, R - RIP, S - static
           M - mgmt, U - route usable, * - candidate default, V - RAPNG VPN/Branch
    Gateway of last resort is Imported from DHCP to network 0.0.0.0 at cost 10
    Gateway of last resort is Imported from CELL to network 0.0.0.0 at cost 10
    Gateway of last resort is Imported from PPPOE to network 0.0.0.0 at cost 10
    Gateway of last resort is 192.168.0.1 to network 0.0.0.0 at cost 1
    S*    0.0.0.0/0  [1/0] via 192.168.0.1*
    C    10.57.30.32/29 is directly connected, VLAN1
    C    192.168.0.0/24 is directly connected, VLAN10
    (Aruba7005) #ping 8.8.8.8 source 10
    Press 'q' to abort.
    Sending 5, 92-byte ICMP Echos to 8.8.8.8 from 192.168.0.117, timeout is 2 seconds:
    Success rate is 0 percent (0/5)
    (Aruba7005) #
  • 4.  RE: Controller 7005 - issues with inter-vlan routing
    Posted Sep 06, 2018 02:46 PM
    To simplify this, i've removed the cradlepiont and plugged the internet circuit directly into the 7005.
    (Aruba7005) (config) #show ip interface brief
    Interface                   IP Address / IP Netmask        Admin   Protocol   VRRP-IP         (VRRP-Id)
    vlan 1                     10.57.30.33 / 255.255.255.248   up      up         none            (none)
    vlan 10                  72.173.194.58 / 255.255.254.0     up      up         none            (none)
    loopback                    unassigned / unassigned        up      up
    DHCP is enabled on VLAN(s) 10
    (Aruba7005) #ping 4.2.2.2
    Press 'q' to abort.
    Sending 5, 92-byte ICMP Echos to 4.2.2.2, timeout is 2 seconds:
    Success rate is 80 percent (4/5), round-trip min/avg/max = 43.158/340.302/639.063 ms
    (Aruba7005) #ping 4.2.2.2 source 1
    Press 'q' to abort.
    Sending 5, 92-byte ICMP Echos to 4.2.2.2 from 10.57.30.33, timeout is 2 seconds:
    Press 'q' to abort.
    Success rate is 80 percent (4/5), round-trip min/avg/max = 26.27/334.347/638.342 ms
    S*    0.0.0.0/0  [10/0] via 72.173.194.1*
    C    72.173.194.0/23 is directly connected, VLAN10
  • 5.  RE: Controller 7005 - issues with inter-vlan routing
    Posted Sep 06, 2018 03:46 PM
    Press 'q' to abort.
    Press 'q' to abort.
    Press 'q' to abort.
    You will not be able to ping Internet resources from your 10.0.0.0/8 IP address space, because that space is not routable over the Internet. 4.2.2.2 has no way to reply to 10/8, and traffic from that address space is most likely blocked at ingress into your ISP.
    Similarly, without looking at the CradlePoint's configuration, it most likely does not know to send traffic to 10.57.30.32/29 to the controller at 192.168.0.117. Routing information would need to be learned, either through static configuration or via a dynamic routing protocol.
    If connecting the 7005 directly to the ISP is supposed to work, then there needs to be a device in the network that performs NAT for the 10/8 network. Since the CradlePoint is connected to the ISP, it typically would handle that, but the 7005 can perform that function as well.
  • 6.  RE: Controller 7005 - issues with inter-vlan routing
    Posted Sep 06, 2018 04:08 PM
    Probably should have mentioned this but I put a nat on the vlans so that I could get out to the internet.  Sorry, I thought that would be implied.
  • 7.  RE: Controller 7005 - issues with inter-vlan routing
    Posted Sep 06, 2018 05:16 PM
    What is your nat configuration?
  • 8.  RE: Controller 7005 - issues with inter-vlan routing
    Posted Sep 06, 2018 05:24 PM
    interface vlan 1
            ip nat inside
    interface vlan 10
            ip address dhcp-client
            ip nat outside
