Controller acting as Router
  • 1.  Controller acting as Router
    Posted Oct 11, 2014 11:27 AM
    Hello all.
    Lightning had its way with my home router last night.
    Im trying to configure the controller (3200xm) in my lab to behave as the router. Im a Hulu only household and its nasty weather outside so this is pretty important(JK).
    So far i am having no luck with the configuration. I have the public address and def. gateway assigned to a VLAN (999) and placed on a port. I have inter VLAN routing in place for the other VLANs and source nat enabled for 999, everything is trusted. What am i missing?
    Im sure some of you experts can show me the way. What is the easiest way to accomplish this?
    Many thanks for future help.
  • 2.  RE: Controller acting as Router
    Posted Oct 11, 2014 11:30 AM
    Try adding "ip nat inside" to your internal vlan interfaces.
  • 3.  RE: Controller acting as Router
    Posted Oct 11, 2014 11:39 AM
    Cappalli: I applied it to the internal VLANs with no luck on getting out. Ill try any other ideas as well.
    Thanks for you time also.
  • 4.  RE: Controller acting as Router
    Posted Oct 11, 2014 03:36 PM
    Look at your show ip route
  • 5.  RE: Controller acting as Router
    Posted Oct 11, 2014 10:17 PM
    @JonMwifi wrote:
    Hello all.
    Johnmwifi,
    What device is the 3200XM replacing in your existing network?
  • 6.  RE: Controller acting as Router
    Posted Oct 11, 2014 10:53 PM
    You mention that you have source NAT on VLAN 999 and that is your public IP.  You don't want source NAT enabled on your public interface; you want it enabled on your other internal VLANs.
    My gateway is a 3200XM as well.   Relevant portions of config:
    interface vlan 192
            ip address 192.168.13.254 255.255.255.0
            ip nat inside
            description "home-net"
    interface vlan 470
            ip address dhcp-client
            description "xfinity-vlan"
    interface gigabitethernet 1/3
            description "xfinity-uplink"
            trusted
            trusted vlan 1-4094
            ip access-group "XFINITY-LINK-ACL" session
            switchport access vlan 470
    ip default-gateway import dhcp
    ip access-list session XFINITY-LINK-ACL
      any any svc-dhcp  permit
      any any any  deny
  • 7.  RE: Controller acting as Router
    Posted Oct 13, 2014 01:07 PM
    Sorry for the delay in response.
    Clembo you are a lifesaver. This got me going. I was trying to staticly set the public details and when i changed to dhcp on vlan 999 and fixed the source nat issue i got going.
    Again I REALLY thank you.
  • 8.  RE: Controller acting as Router
    Posted Oct 25, 2016 12:59 PM
    Can't wait to get home and build out a new lab this weekend! Looking forward to a solid deployment for a change!
    Thanks!!!
  • 9.  RE: Controller acting as Router
    Posted Feb 11, 2020 01:36 AM
    Do we need a license for use Aruba mobility controller as a router in a third party network environment?
