Controller and home setup
  • 1.  Controller and home setup
    Posted Aug 21, 2019 05:35 PM
    So I'm new to aruba and setting up a lab at home behind a LTE router.
    I have a 7005 basically no config other than the following done. What i'm seeing is I can't get internet access from the controller/LAN. I tried doing a ping 8.8.8.8 source 99 and ping 8.8.8.8 source 20, should I be able to get internet access or am i missing something? I can reach the gateway of the LTE router fine which is on VLAN 99, the controller is on VLAN 1. Doesnt seem like I can change the controller to VLAN 99 because it's got DHCP setup.
    (Aruba7005) *[mynode] #show vlan
    VLAN CONFIGURATION
    VLAN Description Ports AAA Profile Option-82
    1 Default GE0/0/2-0/3 Pc0-7 N/A Disabled
    20 LAN GE0/0/1 N/A Disabled
    99 LTE_Router GE0/0/0 N/A Disabled
    (Aruba7005) *[mynode] #show ip interface b
    Interface IP Address / IP Netmask Admin Protocol VRRP-IP
    vlan 1 172.16.0.254 / 255.255.255.0 up up
    vlan 99 192.168.1.24 / 255.255.255.0 up up
    vlan 20 192.168.2.1 / 255.255.255.0 up up
    loopback unassigned / unassigned up up
    sh(Aruba7005) *[mynode] #show ip route
    Codes: C - connected, O - OSPF, R - RIP, S - static
    M - mgmt, U - route usable, * - candidate default, V - RAPNG VPN/Branch
    Gateway of last resort is Imported from DHCP to network 0.0.0.0 at cost 10
    Gateway of last resort is Imported from CELL to network 0.0.0.0 at cost 10
    Gateway of last resort is Imported from PPPOE to network 0.0.0.0 at cost 10
    S* 0.0.0.0/0 [10/0] via 192.168.1.1*
    C 172.16.0.0/24 is directly connected, VLAN1
    C 192.168.1.0/24 is directly connected, VLAN99
    C 192.168.2.0/24 is directly connected, VLAN20
    Interface gig 0/0/0 connected to LTE router
    interface gigabitethernet 0/0/0
    trusted
    trusted vlan 1-4094
    switchport access vlan 99
    vlan 99
    interface vlan 99
    ip address dhcp-client
    ip default-gateway import
    I also created a seperate VLAN for clients but haven't even really done much with that yet
    ip dhcp pool LAN
    default-router 192.168.2.1
    dns-server import
    lease 1 0 0
    network 192.168.2.0 255.255.255.0
    vlan 20
    interface vlan 20
    ip address 192.168.2.1 255.255.255.0
    ip nat inside
    no shut
  • 2.  RE: Controller and home setup
    Posted Aug 21, 2019 05:46 PM
    Every VLAN interface that you want to be able to go out to the internet should have ip nat inside.
    You can give VLAN 99 a static ip address and statically point your default gateway to that gateway's ip address.  Import is only really for if you want it to obtain the WAN ip address.
    Whatever the controller's management VLAN is should have ip nat inside (type show controller-ip).
  • 3.  RE: Controller and home setup
    Posted Aug 21, 2019 07:25 PM
    Makes sense since this like you said really isn't connected to any sorta WAN but a router. However I did change the VLAN 99 interface to static IP and also change the default gateway still no love. IP nat inside is also enabled on the interface. Tried pinging google DNS 8.8.8.8 sourcing from VLAN 99 and also just from the controller, gateway is reachable.
    interface vlan 99
    ip address 192.168.1.24 255.255.255.0
    ip nat inside
    ip default-gateway 192.168.1.1
    (Aruba7005) *[mynode] #show ip interface brief
    (Aruba7005) *[mynode] #ping 8.8.8.8 source 99
    Press 'q' to abort.
    Sending 5, 92-byte ICMP Echos to 8.8.8.8 from 192.168.1.24, timeout is 2 seconds:
    Success rate is 0 percent (0/5)
    Press 'q' to abort.
    Sending 5, 92-byte ICMP Echos to 8.8.8.8, timeout is 2 seconds:
    (Aruba7005) *[mynode] #ping 192.168.1.1
    Press 'q' to abort.
    Sending 5, 92-byte ICMP Echos to 192.168.1.1, timeout is 2 seconds:
    Success rate is 100 percent (5/5), round-trip min/avg/max = 0.874/1.611/2.216 ms
  • 4.  RE: Controller and home setup
    Posted Aug 21, 2019 07:30 PM
    You shouldn't have to do ip nat inside on VLAN 99, because the router itself should be natting that.  What is the result of "show ip route"?
  • 5.  RE: Controller and home setup
    Posted Aug 21, 2019 07:36 PM
    I tried with and without ip nat inside and the routing table is the same see below.
    Gateway of last resort is 192.168.1.1 to network 0.0.0.0 at cost 1
    S* 0.0.0.0/0 [1/0] via 192.168.1.1*
    And without it
  • 6.  RE: Controller and home setup
    Posted Aug 21, 2019 07:42 PM
    Ping 8.8.8.8 and then type "show datapath session table 8.8.8.8" to see if any of that traffic is being denied.
  • 7.  RE: Controller and home setup
    Posted Aug 21, 2019 07:45 PM
    I'm not too familiar with this table but it looks like two way traffice but as you can see no success.
    Press 'q' to abort.
    (Aruba7005) *[mynode] #show datapath session table 8.8.8.8
    Q - Real-Time Quality analysis
    u - Upstream Real-Time Quality analysis
    E - Media Deep Inspect, G - media signal
    r - Route Nexthop, h - High Value
    A - Application Firewall Inspect
    B - Permanent, O - Openflow
    L - Log
    Source IP Destination IP Prot SPort DPort Cntr Prio ToS Age Destination TAge Packets Bytes Flags
    192.168.1.24 8.8.8.8 1 70 2048 1/4108 0 0 0 local 9 1 120 FCI
    8.8.8.8 192.168.1.24 1 69 0 0/0 0 22 0 local a 1 96 FI
    192.168.1.24 8.8.8.8 1 67 2048 1/4108 0 0 1 local c 1 120 FCI
    192.168.1.24 8.8.8.8 1 66 2048 1/4108 0 0 1 local c 1 120 FCI
    8.8.8.8 192.168.1.24 1 68 0 0/0 0 22 1 local b 1 96 FI
    8.8.8.8 192.168.1.24 1 66 0 0/0 0 22 1 local e 0 0 FI
    192.168.1.24 8.8.8.8 1 68 2048 1/4108 0 0 1 local d 0 0 FCI
    8.8.8.8 192.168.1.24 1 70 0 0/0 0 22 1 local b 0 0 FI
    192.168.1.24 8.8.8.8 1 69 2048 1/4108 0 0 1 local c 0 0 FCI
    8.8.8.8 192.168.1.24 1 67 0 0/0 0 22 1 local e 0 0 FI
  • 8.  RE: Controller and home setup
    Posted Aug 21, 2019 07:53 PM
    What is the output of "show controller-ip" ?
  • 9.  RE: Controller and home setup
    Posted Aug 21, 2019 07:57 PM
    It's on VLAN 1 with a 172.x address do I need to change this to my VLAN 99 address? If so why wouldn't just doing a "ping 8.8.8.8 source 99" work?
    (Aruba7005) *[mynode] #show controller-ip
    Switch IP Address: 172.16.0.254
    Switch IP is configured to be Vlan Interface: 1
    Switch IPv6 address is not configured.
  • 10.  RE: Controller and home setup
    Posted Aug 21, 2019 08:00 PM
    Please change it to VLAN 99.  I have no idea why it wouldn't work, but it could be an issue.
  • 11.  RE: Controller and home setup
    Posted Aug 21, 2019 08:10 PM
    Still no luck there.
    Switch IP Address: 192.168.1.24
    Switch IP is configured to be Vlan Interface: 99
    Press 'q' to abort.
    Success rate is 100 percent (5/5), round-trip min/avg/max = 2.126/2.3108/2.725 ms
    Press 'q' to abort.
    L - Log
    192.168.1.24 8.8.8.8 1 11 2048 1/4108 0 0 1 local 1a 0 0 FCI
    8.8.8.8 192.168.1.24 1 13 0 0/0 0 22 1 local 19 0 0 FI
    8.8.8.8 192.168.1.24 1 11 0 0/0 0 22 1 local 1a 0 0 FI
    192.168.1.24 8.8.8.8 1 13 2048 1/4108 0 0 1 local 19 0 0 FCI
  • 12.  RE: Controller and home setup
    Posted Aug 21, 2019 08:13 PM
    I would do a traceroute and find another ip address to ping.  It is possible 8.8.8.8 is blocked.
