Controller AP & RAP Limits
  • 1.  Controller AP & RAP Limits
    Posted Apr 30, 2013 01:37 PM
    i have a Controller ( 3200 )
    currently carrying the maximum APs : 32 AP
    i will get LIC for RAPs  ( 128 RAP )
    is there any limitation that this Cobtroller will carry both  32*AP & 128 RAP  simultaneously ?
    #3200
  • 2.  RE: Controller AP & RAP Limits
    Posted Apr 30, 2013 01:38 PM
    That's correct .
    But on 6.2 that will change
  • 3.  RE: Controller AP & RAP Limits
  • 4.  RE: Controller AP & RAP Limits
    Posted Apr 30, 2013 03:14 PM
    didnot get the answer :)
    so i can do the below or not :
    is there any limitation that this Cobtroller ( 3200 ) will carry both  32*AP & 128 RAP  simultaneously ?
  • 5.  RE: Controller AP & RAP Limits
    Posted Apr 30, 2013 03:33 PM
    Unfortunatetly you can't run it simultaneously
    For 4 RAPs licenses  you will be using 1 Campus AP license.
  • 6.  RE: Controller AP & RAP Limits
    Posted Apr 30, 2013 09:42 PM
    @Telnet-1;   vfabian is right.   You cannot simultaneously use 128 RAPs and 32 CAPs.    You can have all sorts of combinations of both RAPs and Campus APs, but you cannot exceed the platform limit; in this case the 32 APs .    You'd need to do some math, but for simplicity, consider each RAP 1/4 of a Campus AP.    For example, you could have 30 Campus APs and 8 RAPs.   Or 20 Campus APs and 48 RAPs.   etc......
  • 7.  RE: Controller AP & RAP Limits
    Posted May 02, 2013 08:30 AM
    Ok , i understood Limits now
    what about licenses ?
    let's assume i will have 4 AP + 4 RAP  , will i need  4* AP LIC  + 1* AP LIC  ......   or   4* AP LIC   + 4* RAP LIC    .......   or  4*AP LIC + 1* AP LIC  +  4* RAP LIC   ?
  • 8.  RE: Controller AP & RAP Limits
    Posted May 02, 2013 08:32 AM
    So if you get 4 AP licenses you will get 16 RAPs licenses
  • 9.  RE: Controller AP & RAP Limits
    Posted May 02, 2013 10:27 AM
    The 4:1 ratio is for sizing/capacity only.    For licensing, you need an AP license for every AP, whether it is a campus, remote, or mesh AP.  Your example of 4 AP + 4 RAPs would require a total of 8 AP licenses.
  • 10.  RE: Controller AP & RAP Limits
    Posted May 02, 2013 01:55 PM
    Hi clembo ,
    You said :
    "Your example of 4 AP + 4 RAPs would require a total of 8 AP licenses."
    does this mean i will need no RAP LIC at all ?
  • 11.  RE: Controller AP & RAP Limits
    Posted May 02, 2013 02:09 PM
    There is no "RAP" specific license anymore, only AP licenses.
  • 12.  RE: Controller AP & RAP Limits
    Posted May 02, 2013 03:53 PM
    But Price list still have the below :
    LIC-1-RAP
    LIC-4-RAP
    LIC-6-RAP
    LIC-8-RAP
    LIC-16-RAP
    LIC-24-RAP
    LIC-32-RAP
    LIC-48-RAP
    LIC-64-RAP
    LIC-128-RAP
    LIC-256-RAP
    LIC-512-RAP
    LIC-1024-RAP
  • 13.  RE: Controller AP & RAP Limits
    Posted May 02, 2013 03:56 PM
    That is for pre ArubaOS 5.x.  The pricelist should have columns to the right that say 5.x and 3.x and an appropriate "yes" or "no".  If you are running 3.x, then yes, you'd need RAP licenses.
  • 14.  RE: Controller AP & RAP Limits
    Posted May 03, 2013 06:31 AM
    Thansk  alot
    so you mean that i shouldnot use RAP LIC , i got it
    i shall use only AP LIC , so if i have 4 RAP i will  get 4 AP LIC
    but if so , what is the meaning of saying that controller can have 128 RAP while it can have  only 32 AP LIC ?
  • 15.  RE: Controller AP & RAP Limits
    Posted May 03, 2013 07:34 AM
    I believe if you bought a LIC-X-RAP license, you can still assign it to a controller's serial number in the licensing portal.  Then, when you view the certificates; select the "Post 5.0" option from the drop down.  I believe your RAP license will be convereted to an AP license.   I don't have a license to check with, but seem to remember this for customers back during 3.x to 5.x upgrades.
    A 3200 controller has an Campus AP capacity of 32.  A Remote AP capacity of 128.  You can load up to 128 AP licenses on the controller for use of both Campus and Remote APs.  However, for calculation of the capacity, you need to use the formula mentioned ealier.    1 CAP = 4 RAP.    This is purelfy for the sizing, not licensing.
    Assume Campus AP = X
    Assume Remote AP = Y
    You can have any number of combinations, so long as X + (4 * Y) is less than or equal to 128 (for the 3200).
  • 16.  RE: Controller AP & RAP Limits
    Posted May 03, 2013 08:08 AM
    Thanks a Million
    got it now , it was hard for me :smileyhappy:
  • 17.  RE: Controller AP & RAP Limits
    Posted May 03, 2013 06:56 AM
    4 RAP = 1 AP license
