Controller AP to IAP
  • 1.  Controller AP to IAP
    Posted Dec 22, 2017 09:37 AM
    Hi All,
    Would it be possible to convert a controller 305 AP (purchased as controller based) to instant?
    Thanks!
  • 2.  RE: Controller AP to IAP
    Posted Dec 22, 2017 09:39 AM
    It is not possible, unfortunately.
  • 3.  RE: Controller AP to IAP
    Posted Dec 22, 2017 09:42 AM
     ok, thanks that is all I needed to know. a bit unfortunal indeed.
  • 4.  RE: Controller AP to IAP
    no that will not be possible
