Controller base and controller less setup client roaming impact
  • 1.  Controller base and controller less setup client roaming impact
    Posted Jul 25, 2018 11:25 AM
    Will it be any wireless client connectivity impact while he roam from controller base setup to controlless IAP setup for the same SSID, authentication method and VLAN.
    Thank you...
  • 2.  RE: Controller base and controller less setup client roaming impact
    Posted Jul 25, 2018 11:30 AM
    For stateful applications, yes.
  • 3.  RE: Controller base and controller less setup client roaming impact
    Posted Jul 25, 2018 11:37 AM
    Thank you for quick reply...
    how much time client will take to reconnect the SSID
  • 4.  RE: Controller base and controller less setup client roaming impact
    Posted Jul 25, 2018 11:35 AM
    The user will miss a few pings as it performs a full reauth / re-dhcp because the information is not shared between the two environments
    Sent from Mail for Windows 10
