Controller Boot Error
  • 1.  Controller Boot Error
    Posted Feb 08, 2012 10:13 AM
    I have a backup controller that displays the following error during boot up...
    CPBoot 1.2.0.0 (build 20527)
    Built: 2009-01-20 at 18:55:40
    DRAM:  Operating at 533 MHz
    DRAM:  Channel 0: 1024 MB
    Unable to locate a working CMD and/or SLV_CMD strobe configuration for this channel.
    The controller lost power before this problem started, does this mean the memory is fried or is there something I can do to get past this point?
  • 2.  RE: Controller Boot Error
    Posted Feb 08, 2012 02:40 PM
    Certainly not user serviceable.  Please call support.
  • 3.  RE: Controller Boot Error
    Posted Jan 10, 2016 07:58 AM
    I encounter the same error.
    But fixed by swapping the RAM to each other slot
  • 4.  RE: Controller Boot Error
    Posted Feb 14, 2018 05:00 AM
    Yesterday,
    I got boot error.
    My problem is slot0 suddenly defective.
    My RAM are 512KB x 2
    Everytime I put RAM on slot0, boot error happen.
    If I only put on slot1, it will boot but stuck on uncompressing image.
    I suspect that because not enough RAM
    So I bought 1GB DDR2 PC RAM and put into slot1 (leave slot0 empty)
    Now my 3400 working again
