controller btu ratings
  • 1.  controller btu ratings
    Posted Jun 06, 2014 12:36 PM
    Does anyone know the BTU rating of a 650 controller?
  • 2.  RE: controller btu ratings
    Posted Jun 06, 2014 01:21 PM
    The BTU of the 650 is 163.82 BTU/hr .
  • 3.  RE: controller btu ratings
    Posted Jun 06, 2014 01:24 PM
    Thank you
  • 4.  RE: controller btu ratings
    Posted Jun 23, 2014 07:26 PM
    Hi.
    Could you please explain me how do you calculated that value?
    Thanks in advance.
  • 5.  RE: controller btu ratings
    Posted Jun 23, 2014 11:33 PM
    It is published internally at Aruba.   I cannot share the full document, but if you have a specific component you are interested in chekcing, let me know.  If you need further validation of this setting, please talk to your local Aruba sales team or partner.
  • 6.  RE: controller btu ratings
    Posted Jun 24, 2014 10:35 AM
    Hi, don´t worry I found the way to do it (I guess).
    P(BTU/hr) = 3.412141633 × P(W)
    On the 650 datasheet specifies
    Power Specifications
    • Maximum power consumption: 126 watts
    • Power-over-Ethernet total capacity: 78 watts
    • Power-over-Ethernet capacity per port: 19.5 watts
    So I take the max power and substract the total PoE.
    126watts - 78watts = 48 watts
    This is valid for a controller that is no using the PoE
    If you use a port with PoE you should add 19.5 watts
    The we have to calculete the BTU
    P(BTU/hr) = 3.412141633 x 48 watts = 163.78.27
    Thanks for the help.
