Controller can's see the AP
  • 1.  Controller can's see the AP
    Posted Jul 30, 2017 10:52 PM
      I am adding new APs, I have 72xx controller. Two days ago  I added 12 new APs and everything works find. Today I am trying to add new 10 AP but for some reason the controller can't see them!!!! Some useful infromation:
    1- The ap get a DHCP address and find the master controller.
    2- There is no problem with the switching, I am using the same switch that I used two days ago.
    3- I did checked out plan security and it was disabled.
    and thoughts would be appreciated.
  • 2.  RE: Controller can's see the AP
    Posted Jul 30, 2017 11:11 PM
    Are you trying to add the same type of APs ?
    Can you ping the controller from the AP Console ?
    Get Outlook for iOS
  • 3.  RE: Controller can's see the AP
    MVP EXPERT
    Posted Jul 31, 2017 03:40 AM
    Don't forget to also check that the firmware running on your controller is also supported by the new AP's.
  • 4.  RE: Controller can's see the AP
    Posted Aug 02, 2017 02:46 AM
    The Image is the latest and I do have 15 AP 335 working fine without any probelme. Now I am tring to add another 10 but it is not working.
  • 5.  RE: Controller can's see the AP
    Posted Aug 02, 2017 02:48 AM
    APs are the same type. I can ping the controller from the AP.
  • 6.  RE: Controller can's see the AP
    Posted Aug 02, 2017 04:51 AM
    Type "show log system 50" to see if you can see what the problem is.
    Type "show ap database" to see if those new APs have flags..
  • 7.  RE: Controller can's see the AP
    Posted Aug 03, 2017 12:36 AM
      I deployed Aruba tons of times and this is not my first time, but never had such an issue. For some reason the 335 AP act up each once in a while, I notice that for the third time in a row. I didn't change anything and after 3 days the APs came up. There is no logically exploration for that, but anyway, those APs are up an running now without any change from my side.
  • 8.  RE: Controller can's see the AP
    Posted Aug 03, 2017 07:41 AM
    What discovery method are the access points using to find the controller?
  • 9.  RE: Controller can's see the AP
    Posted Aug 03, 2017 05:32 PM
     We are using option 43 and optoin 60. That being siad, the contorller and the APs are in the same Vlan, so adp should be good also. just like what I said, 15 AP came up without an issue eariler.
  • 10.  RE: Controller can's see the AP
    Posted Aug 03, 2017 06:06 PM
    Do you have enough licenses ?
    VIA the AP console can you see that the AP is discovering the controller ?
    Do you have CPSec enabled ?
